Results 1 to 6 of 6
- Jan 2004
- 19
February 10th, 2004 08:33 PM #1kelan ba? kasi sa PMS ng honda wala namang schedule kung kelan. pag medyo nagiging delayed ang shifting un kaya solution doon? or symptom ng ibang problem pa? TIA
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 11th, 2004 10:39 AM #2have you replaced the at fluid? you may find this a better, yet temporary solution to the problem
- Jan 2004
- 19
February 11th, 2004 11:18 AM #3yup. changed it about 6months ago. minsan lang parang delayed shifting. hindi naman grabe but annoying at times. im thingking that maybe the filter needs to be replaced na.
- Jan 2004
- 19
February 11th, 2004 12:34 PM #4double post
- Feb 2004
- 129
February 12th, 2004 11:29 AM #5If the car has more than 100K kms already, it should not be a bad idea to have the A/T filter replaced. Are you sure Honda does not specify the schedule for A/T filter replacement? I think for the Civic they call for a filter replacement together with the ATF at 80K kms.
Slow shifting can also be caused by worn out brake bands. These may be adjusted yet and may not need replacement for the next 50K kms.
- Jan 2004
- 19
February 13th, 2004 12:54 AM #6i have a crv and had the ATF replaced during the 40K PMS. replacement of the AT filter is not indicated anywhere on the PMS schedule. well, maybe they will advise me to replace it during the 80k pms.
ill check on the brake bands. thanks!
Xiaomi E-Car
