Results 1 to 10 of 15
November 24th, 2008 02:39 PM #1
Hey guys, need your expert advice on this one.
Which oil viscosity will you use for racing or even just a fast road set up engine(like slightly modified engines), SAE 0w40 or SAE 10w60?
any inputs would be very much appreciated!
November 24th, 2008 03:19 PM #2
10w60? That's way too thick.
For an old engine, where you're not sure of the tolerances, 20w50 is safe... for newer performance engines, you'd go for 0w20 or 10w30... the smaller the range (the difference between the two numbers), the less additives in the oil and the better its resistance to breakdown... in fact, you can use straight 30 or straight 40 oil for the racetrack, but they're not recommended for road use.
10w30 or 10w40 is okay for daily use. 20w50 for older engines... all depending on the engine in particular. Engine safety first before extra performance. ;)
November 25th, 2008 09:52 AM #3
10W-30 if your engine can take it.
Some engines that is geared to maximize fuel consumption can take in 5W-30 too.
__________________
bigbigcar.com Review: Chery QQ3 1.1 MT
Small car, big ambitions: The Chery QQ is the vanguard of the Chinese invasion.
- Apr 2004
- 66
November 27th, 2008 04:31 PM #4robin micmac, hi!
i would suggest you to read the post thread regarding - http://ferrarichat.com/forum/faq.php...tor_oil_basics ... hope this helps, it's very long yet very enlightening. God bless!
henry
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 30th, 2008 04:25 PM #5not the 10w60 definitely.
what engine is it for? what are the mods? if it's built what clearances did you use?
December 1st, 2008 08:42 AM #6
we use Royal Purple OR Valvoline synthetic 10W30 & 15W50 for our race cars. and sometimes we use Redline synthetic oil.
aite, peace.
December 1st, 2008 10:05 AM #7
- Nov 2003
- 3,848
December 1st, 2008 05:17 PM #8pwede but shorter interval than the reg full syn since it's racing oil.
December 2nd, 2008 11:57 PM #10
I was just actually curious because ive seen some people using MOTUL 300V Le Mans 20W60 during hillclimb events and some races in BRC. 20W60 is even thicker Although most of them use it on older engines. I saw it being used on a Porsche 911.i was just wondering if they get really better protection from it
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
