Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
    Nov 2003
    #21
    take out the key. it's as simple as that.
    Aug 2007
    #22
    thanks guys for all the info, minsan kasi napapaisip din ako bakit nga naman kelangan pa mag rev before nila off yung engine. magagaling pagdating sa sasakyan yung mga tito ko at ibang mga kakilala pero pag nag switch off sila ng engine kelangan mag rev muna, talagang pinapaiyak muna nila yung engine nila sabay off ng engine.
    Aug 2005
    #23
    He he he tinamaan ako don ah! Before I used to do that with my ride,but ask ko for what?
    So now,off all accessories then cool down for a minute then switch off engine,syempre different pag your in a hurry Switch off engine sabay takbo he he he joke!
    #24
    simply turn it off without revving.
    #25
    black smoke ba ang lumalabas pag nag high rev sila? alam ko pag ganyan, they're decarbonizing the engine lalo na pag mostly after normal speed driving.
    maganda mag decarbonize is mag high speed driving ka pero bawal na sa slex. punta ka sa BRC
    but this is for another thread
    Quote Originally Posted by glenngj View Post
    Jan 2003
    #26
    poor cars, i'm sure di magtatagal lalabas yung sira nun, ako nga before i drive my car on road, idle ko muna ng at least 3mins and 30 mins before i switch on my aircon..
    Aksaya lang din sa gasolina yan. If you have a properly working thermostat, then the proper way to warm up the engine is to drive off, pero hinay-hinay lang muna until it reaches operating temp.
    Aug 2007
    #27
    Quote Originally Posted by tibo_3rd View Post
    wala naman black smoke na lumalabas, siguro nga nakasanayan na lang nila yun. pero sabi nila ginagawa nila yun para kinabukasan pag nag start sila ng engine, one click lng.
    Aug 2007
    #28
    Quote Originally Posted by Yoda View Post
    hindi naman siguro aksaya sa gas kasi kinukundisyon ko muna yung engine for 3mins and after that patatakbuhin ko na.. after 10-30mins saka ko bubuksan yung aircon.
    #29
    idle lang oto for 3mins na nakahigh blower para medyo matuyo air filter then switch off na.
    Nov 2003
    #30
    remove the key.
    Dec 2007
    #31
    hehehe.. lolz!
    ako, I just let the car idle a little bit and then shut it off (specially on my daily drivers..) but if its my Supra, I let the Turbo Timer do its job (usually 30 seconds on normal driving and 1 min after a pass on the drag strip.. or after a freeway run.)
    aite, peace.
    Aug 2007
    #32
    sir kbr sa vallejo lang kayo malapit sa marine world? i hope next year makabalik ako dyan..hehehe..
    Dec 2007
    #33
    depends sa running hours mo... for long distance travel... cool down ka muna before swithcing off... pero kung sa pangmalapitan lang... off mo na...
    By the way,, FYI lang... Diesel engine is not for long idling.... basta nasa Normal operating temperature na sya.. if possible iload nyo na kaagad... long idling will cause unburned diesel to mix with your oil... parang dillution na rin yun ng engine oil and diesel.....
    although oil din ang diesel, pero yung viscosity nya ay di gaya ng engine oil... it will affect your car's internal parts...
    Dec 2007
    #34
    yes sir! malapit lang kami sa Marine World (which they now changed the name to Discovery Kingdom). anywayz, let me know kung mag babakasyon ka dito para EB! hehehe.
    aite, peace.
    #35
    Quote Originally Posted by sonjeffrey View Post
    Well said bro. Without load the rings seals prematurely against the cylinder walls causing blow by. That is why compression is poor leading to more than normal contamination of the oil due to oxidation.
    In addition, turbo in diesels that are water cooled dessipates the heat more quickly to prevent oil from cooking. A minimal idling is neccesory before shut off unless you just raced it.
what is the proper way of turning your engine off?
