Results 1 to 10 of 15
- Oct 2004
- 58
August 7th, 2005 10:36 AM #2
strong car vibrations especially on low engine rpms. open ur hood and look at the engine, if it moves too much back n forth lalo na when revving then ur engine support might be shot, some can be plainly seen with cracks n damage.
August 8th, 2005 06:48 AM #3
experienced a bad engine support on our 323 familia dati...it really vibrated badly at idle. strangely, contrary to what bluebimmer said, the bad vibes (hahaha, what a term) would go away if the engine was revved. and you'd also hear a chug-chug-chug sound, probably as an aftereffect ng vibrations nga.
what car is this, btw?
***edit***
forgot to add. a week after replacing the 2 engine mounts, akala ko sira nanaman since i had the same bad vibrations. turns out na while washing the engine bay, some water got into the sparkplug holes. hahahahaha. oh well.Last edited by nugundam93; August 8th, 2005 at 06:51 AM.
August 8th, 2005 01:48 PM #4
san po makikita usually engine supports? hehehe sorry ignorante talaga ako pagdating sa sasakyan since 1st time magkasasakyan... btw, my vehicle is mitsu adv ss 02 model.
i usually feel a strong vibration whenever i hit 100kph nowadays but before wala naman khit na umabot pa ako ng 120kph.
Tsikot Member Rank 3
- Dec 2003
- 546
August 8th, 2005 01:50 PM #5di ba yung engine mo suspended sa chassis/kaha? try looking for the points where your engine/transmission na coconnect sa chassis/kaha ng sasakyan mo, youll find the engine support
August 8th, 2005 01:57 PM #6Originally Posted by jvdejesus05
August 8th, 2005 02:01 PM #7
thanks for the immediate feedbacks.
sir baiskee: will try to do some wheel alignment first, which reminds me, medyo matagal na since my last wheel alignment.
- Nov 2004
- 115
August 8th, 2005 04:43 PM #8ganyan ang experience ko sa pajero.. lakas ng vibrations pag idle, pero kapag gas ka.. nawawala..
how much kaya engine support for pajero? and mga how much ang labor?
October 6th, 2005 06:53 PM #9
hi, tanong ko na rin yung sa akin, honda civic lx 1993 po yung car ko, sabi nung mechanic ko kailangan ko na daw bumili ng engine support tatlo daw ata yun, may idea po ba kayo kung saan at magkano yung price ng engine support for my car? thanks po.
October 6th, 2005 07:04 PM #10
malayo presyo ng orig vs replacement btw, mga 3-5x more expensive pero malayo quality and isolation
Daming issue ng SU7:grin:
Xiaomi E-Car
