Results 1 to 2 of 2
- Aug 2008
- 15
August 13th, 2010 03:01 AM #1there's this cranking sound in our focus tdci when you depress the clutch pedal midway.. we'll we brought it to casa and they told us that we need to replace the clutch assembly. then after the clutch got changed the problem still remains. now they told us to replace the flywheel..
and will cost us 38k for the whole assembly.. now my question is.. can the flywheel be repaired? and where can we take it to be repaired?
- Feb 2010
- 27
August 13th, 2010 05:31 AM #2puwede po,reface po yata tawag dun sir.sa mga machine shop po yon pinapareface.ang alam ko po dapat sabay ng pinagawa yon kung ibababa yong transmision mo para isang labor nalang.kasi nung february nagpalit ako ng clutch disc,preasure plate,at release bearing at pina reface na din yong flywheel para pantay yong lapat niya sa clutch disc.mura lang po pareface ng flywheel wala pa po ata 1K ang mahal lang yong labor ng mekaniko na magbababa ulit ng transmision nyo sir.sa casa ata palit agad kung puwede pa naman ipareface.
Because pinoy mentality. Not surprising.
