Page 23 of 26 FirstFirst ... 131920212223242526 LastLast
Results 441 to 460 of 511
    Dec 2007
    #441
    Quote Originally Posted by TheGreenThing View Post
    Im using my windshield washer bottle as my tank which has a 4.xx liters.
    I set my float level switch to light up less than or equal to 2 liters.. That is why i never ran out of juice..
    QUESTION:
    We all know diesel also lubricates the walls of our cylinder right? By using water/meth it steam cleans the walls and taking also the lubrication made by the diesel fuel.. Our putting more stress factor to our engine? Pistong rings may put grooves on our cylinder walls?
    Pls advise, need inputs.
    Just FYI, for every liter of fuel burnt you make around a liter of water vapor in the internal combustion process.
    #442
    fortuner yata yung kay greenthing. madalas siguro maubusan ng fluid yung tank kaya may air pockets?
    I think he evaluated on different nozzle sizes and came out with 4gph. Also the float connection may not be on an ideal position. Very easy to register as no fluid in the controller at short distance use.
    Jul 2010
    #443
    My level sensor lights up less than 2 liters left which is too early hence i never ran out of fluid.
    Regarding air pockets, symptoms is too much vibration during operation.
    Always bleed the air out whenever you ran out of fluid.
    In my case, I forgot to bleed the air out since the day i installed the kit thats the reason im hearing loud "rakatak" sound.
    #444
    Since your tank is just 4 liter capacity and the trigger point is half of your tank, so you won't be able to use it for long distance without refilling it.
    Dvldoc, will the controller shutdown the pump or lessen the pump pressure if the controller is registering no fluid?
    Dec 2007
    #445
    No it just warns you, The pump can be run dry so it does not need to turn off the pump.
    Jul 2010
    #446
    Ooops sorry.. My bad.. My float level is set to ib below 1.xx liter
    Jul 2010
    #447
    Does anyone know where can i buy extra hoses for our kit? Around manila qc area
    Jul 2010
    #448
    Anyone care to share?
    #449
    Wala na ba si dvldoc? PM mo siya baka nandito pa siya, alam ko meron siya. Ilang meter ba ang kailangan mo?
    Jul 2010
    #450
    Boss baka sino sa inyo meron extra 2 meters.. I need it badly.. Kasi nagpakabit ako ng steel bumper, so i meed to relocate my pump which was previously hidden inside the bumper.. Anyone care to donate? ='(
    #451
    If you can wait until July 31, I can give you one.
    Jul 2010
    #452
    Problem solved na!!
    Jul 2010
    #453
    Removed my kit today because
    ill be installing steel bumpers soon.
    Anyway, im having troubles where to place my pump.. Do you guys mind if a ask for some pictures where you put your pump, nozzle, etc.
    Thanks a have a blessed sunday guys
    #454
    You can install it sa loob ng cabin, sa likod kasama ng tank kung walang space sa engine bay.
    Mar 2012
    #455
    Whenever I'd turn mine on if feel a gain in horsepower but I don't see the intake temp going down. This only happened after a reputable shop ( btw... They're the ones who installed it also) adjusted the kit after road testing and dyno. Reason behind that according to them was w/I injection first instAll was wrong but 1st set up is when I saw drastic temp drop but had a drowning feeling on the engine.
    Sent from my iPhone using Tapatalk - now Free
    Dec 2007
    #456
    Maybe you need a smaller nozzle size or need to adjust your set point 7psi is a good turn on point.
    Jul 2010
    #457
    Guys whats up? Any updates about our alcohol injection?
    Dec 2007
    #458
    Berrima diesel has a event tomorrow from 1 to 3pm. I will be there.
    #459
    has anybody tried putting the pump anywhere aside from the engine bay?
    Jul 2010
    #460
    Mine us mounted on the winch motor inside my steel bumper enclosed with a metal box to avoid water splashes..
    Devildoc you think its worth to mount the nozzle in the elbow of the manifold after the throttle body? Im having 2nd thoughts on drilling that metal elbow.. Im currently mounted pre-intercooler..
    My rubber coupling broke a month ago because it was too tight the nozzle adapter to fit between then intercooler & throttle body
Water/Alcohol injection Turbo Diesel use
