Results 21 to 30 of 34
April 19th, 2015 12:01 PM #21
Mga sir pagnagpalit kayo to other gas intayin nyo makailang palit. Pag gas muna kayo 300 pag near empty na then ubusin nyo ulit then same procedure ulit bago kayo magfull tank. Ive been fillinup up petron xtragasoline then nun nagkaron ng engine knock tuwing cruising nagpalit ako ng blaze then nun nawala balik ulit xtragas. Lipat na rin ako gas station. So far wala na knock khit xtragas lang
April 19th, 2015 09:33 PM #22
AFIAK, 93RON ang required sa Vios. 91 is too low. Baka you are looking at US Spec RON where 91RON US =95RON.
Kinda weird that our gas stations are still selling 91RON. Its just too low. Just load up with 95RON to avoid engine knock .
April 19th, 2015 10:13 PM #23
WTF?! That picture I posted was from my Vios' manual. The very same Vios that has been running on 91 octane since I got it, and still able to do over 190 kph on the highway with never an instance of knocking.
It's not weird that our stations are selling 91 RON, because majority of cars sold locally require 91 RON only. Unless it's stated in your manual that the car requires 95 RON, you don't need 95 RON.
April 20th, 2015 09:38 AM #24
ok.... if the recommended fuel is 91 RON, then definitely, baka may underlying causes pa.
pero try mo magtaas ng 95 RON, and see what's the result.
- Nov 2013
- 2,077
April 20th, 2015 09:48 AM #25
- Oct 2009
- 249
May 19th, 2015 09:54 AM #26
May 19th, 2015 10:10 AM #27
Try first the following:
1. Clean the MAF sensor with electric contact cleaner;
2. Replace your spark plugs
3. Load up at another gas station (you may be getting bad fuel)
I use Caltex Silver now on my Altis and we don't have engine knock issues unless i short shift and release the clutch abruptly (to starve the a/f mix)... It was the same when we used Shell unleaded on a Vios 1.3, no knock issues. Our other Altis uses LPG (100+ octane) and it never has engine knock.
- Jan 2015
- 468
May 19th, 2015 12:49 PM #28Mukhang hindi engine knock problema ni sor TS, either ung parang karambola sa CatCon or ung compressor ng vios, which is maingay talaga lalo na kung naka middle setting ka lang.
- Oct 2009
- 249
- May 2015
- 3
May 19th, 2015 04:15 PM #30Question lang mga boss.wala pako masyado alam sa kotse.ano ba mas maganda sa tubeless flat tire cold or hot patch?salamat
Are they on track to surpass last year's sales?
Car Sales Data (2025)
