Originally Posted by
yebo
Tinatakot nyo naman yung bata. I've seen engines never been ran for 10 years and started with no pre-lubrication with no effects whatsoever. Walang kaso yan may oil film pa din between wearing parts basta huwag lang i-high rev until the oil circulates. Kung gusto sure gawin mo suggestion ni innova, patakan mo ng oil sa spark plug hole. Pati na din cylinder head buhusan mo mga 1 cup new oil then crank by hand sa crankshaft pulley.
Pull out the spark plugs baka kinalawang kaya ayaw mag start. And yes do drain the old gasoline and change with fresh batch. Brakes? Run with the brake pedal pressed down to clean the brake surfaces, preferably in forward and reverse. Pag ok na dalhin mo sa nearest shop for a oil change and tune up.
Hindi tumitigas ang langis. Tamod yun nagiging sago.
