Results 21 to 30 of 37
August 16th, 2015 04:15 PM #21
If the cam lobes are worn out, the cam lift and duration (angle of cam rotation from opening to closing) changes and should be replaced. The clearance in the specs should still be followed. If it still makes tappet noise, the cams are either worn out or misadjusted. Or sometimes like on Toyota 22re, 22 rc or 22rte, the tappet adjusting screw end wears out and you thought the clearance was sufficient until the cams rotate. In the latter case, you replace the rocker arm adjusting screw
- Aug 2015
- 109
August 16th, 2015 04:28 PM #22ang nasa manual po .20mm sa intake at .25mm sa exhaust. ang ginawang adjustment, .15mm sa intake at .16mm sa exhaust. so mali po ung adjustment? hindi ko na po aantayin na maka1 week?
August 16th, 2015 04:35 PM #23
- Aug 2015
- 109
August 16th, 2015 04:48 PM #24sinabi ko na na ung nasa manual ang kulit , pag luma daw iba na....
maraming salamat sir jick.
- Aug 2015
- 109
August 20th, 2015 02:46 PM #25guys napaayos ko na ung valve clearance sa ibang mekanik, halos wala na pong tunog, mahinang mahina na lang, mawawala na daw un pag bumiyahe ng malayo. ang problema po na lost/lose thread (tama ba) ung isang pinagkakabitan ng screw ng valve cover, parang hindi kasing higpit nung iba. magleleak po ba un? anu po pedeng remedyo dun? tia..
August 20th, 2015 03:25 PM #26
Lose thread po. Some machine shops have the tools and know how to fix this. They can re-thread or re-tap that to original. In case of severe damage, slightly bigger diameter tap is needed. And the valve cover screw hole has to be machined. Machine shops can do this and tell you where to get the appropriate screw/bolt needed.
- Aug 2015
- 109
August 20th, 2015 03:34 PM #27sir mahal po ba magparethread? . posible po ba magleak un? kung hindi magleak, iwan ko na lang munang ganun? thanks
- Aug 2015
- 109
August 20th, 2015 03:39 PM #28sir mahal ba magpare thread? magleleak po kaya un?. kung hindi magleak, hayaan ko na lang muna? thanks
August 20th, 2015 03:54 PM #29
They just need to use a tap and dye set. It shouldn't cost much.
As for leaks I dont know.
- Aug 2015
- 109
Xiaomi E-Car
