Results 1 to 10 of 22
- Apr 2003
- 15
May 12th, 2003 03:07 PM #1mga peeps,
i'm just wondering kung kailangan pang mag lagay ng engine flush pag nag change oil? Is it advisable or not? Tnx a lot
May 12th, 2003 04:33 PM #2
Sabi lang sa akin ng isang mechanic, take note sabi lang po ito and I'm not applying it on my engines.
From mineral based oil to full synth oils or vice versa kelangan daw magflushing. (full synth to mineral oils).
Pero kung light oil sludge and your engine is not that old enough, pwede na yung dry pressurized air to flush the used oil out the drain.
May 12th, 2003 10:04 PM #3
ner,
i think it is safe. Eveytime i have my oil changed i use POWER FLUSHING OIL by caltex. According to them its safe because its oil based, not compared to those who contain harmful elements that u mix with the used oil and then flush altogether. In using this u drain first the used oil and then put the drain plug again then put 1/2 of the amount of oil required to your engine. for example if u use 5 liters of engine oil, u can use 2-3 liters of power flushing oil. Then after idling for 5-10 mins, turn off the engine then flush again
ungas,
u know wat , i also had my starex flushed using the high pressure air, they used a rag for it. But CALtEX people have this belief and i think all of them was told not to do this using compressd air inside the engine. It is a fact that this air that came from compressors have water content and we all know that water in a beg no no to our engines, but this shell mechanic was defending his practice that th RAG which i sed a while ago can trap all the water and only air will go in the engine.. Both of them have points but, i thin its better to be safe, but ifthe water will surely be trapped to the rag then no prob. just my advice. tnx :wink:
BANNED BANNED BANNED
- 3,790
May 13th, 2003 06:21 AM #4my mechanic does not recommend the "emulsifier" type because they're "soap" type that will definitely be left inside the engine after flushing and will mix with the new oil...thereby "destroying" the new oil.
that's my mechanic's 2 cents.
I do follow it because it sound logical to me.
May 13th, 2003 07:09 AM #5
Flush oil with oil is the safer bet. My B2200 of almost 11 years now have gone through this. My p-up also passed the emmissions test(I just had the nozzle tips cleaned). After draining the old oil overnight, I buy 2 cans of cheap oil and use it to flush out remnants of the old oil. And using compressed air is not advisable.
May 13th, 2003 07:19 AM #6
i DONT use flush.
i agree with IBALOI. though, medyo magastos. i did it before with my Lancer. talagang makikita mo ba ang dumi that goes with the cheaper oil you use to flush.
May 13th, 2003 08:48 AM #7
i use engine flushing when:
1. first change oil for a newly overhauled engine.
2. changing from mineral to synthetic oil and vice versa.
other than that change oil an filter lang.
- Apr 2003
- 15
- Apr 2003
- 15
FrankDrebin Guest
I dont know kung ano ang major contirbutor sa incident nayan. Dahil ba made in china yung ev car o...
Hybrids and EV
