Na pick up ko to dun sa isang website about veggie oil used for diesel engine as fuel. Ano sa palagay nyo? advisable kaya? di kaya mapadali ang sira ng pistons natin nito?
"Engine carbon build ups can be a problem with diesel fuelled engines which have not been run hard/hot enough. It is advisable to work diesel engines hard fairly regularly to burn this carbon from the engine, more so when running on vegetable oil. A standing start to high speed pedal to the metal run or a very long uphill haul has been shown to help. Extended periods at low engine load or tick over are best avoided when possible. Combustion is less complete when the engine is first started until it reaches operating temperature as the piston rings do not seal as efficiently until the various engine components have expanded with the combustion heat. It is good practice to drive fairly hard upon first starting the vehicle to bring it up to operating temperature as soon as possible."
