Results 1 to 15 of 15
Threaded View
    Feb 2009
    Quote Originally Posted by slowrockmusic View Post
    hahah badtrip nga ako pinihit nya lang distributor ko na tune up na daw, nag self adjust na daw,binuksan nya cylinder head wala sya makitang pinipihit kaya hinde daw na tutune up
    cheap service does not always translate to good service. take it to a qualified service technician. don't be so impressed though, if the shop appears to be well equipped, tools and equipment does mean the technician is trained and experienced.
    now back to the misfire. check which cylinder is uncooperative by unplugging the spark plug wire from the distributor cap with a plastic fuse puller pliers if you are allergic to high voltage spikes and note which cylinder does not cause a change in engine rpm when deactivated. then differentiate whether the misfire is caused by mechanical condition, ignition or fuel ignition.
    what year is this mitsubishi corolla?
TUNE UP Question
