Quote Originally Posted by viepink View Post
Hello! Ask ko lang, ano ba yung Tune up? Kung mgpapa tune up ba mga magkano magagastos? Saka tanong ko rin po sana kung para saan ung Simota Air Intake ba yun? Pwede ba yun sa Mitsu Galant Super Saloon Automatic? thanks!
basically tune-up means to bring into harmony.
sa oto, it means, bringing components together for maximum efficiency, whether few adjustments in certain components or the entire engine itself.
basically, activities done sa tune-up are of follows:
a) replace spark plugs or distributor points
b) replace fuel and air filters
c) check electronic engine management system or ECU
d) timing
e) idling check and adjustment
f) clean carbs/injectors
normally costs around 1000+.
on the Simota intake, its an aftermarket intake system, designed for your car to breathe more efficiently. combustion composes of two factors diba? air and fuel. if the air intake is clogged, it is compared to a person na may congested na ilong. di masyadong makahinga. ang result nung tao, eh mabilis humingal. ganyan din sa oto, make the intake bigger or more efficient and combustion is more efficient.
yes pwede sya sa Mitsu SSaloon.
