Results 1 to 8 of 8
- Jul 2010
- 8
July 9th, 2010 08:46 PM #1mga sir,
bakit ganun po problema ng kotse ko
tumutulo na engine oil pag umaandar ang makina, wala naman pag nakapatay.
simula po nangyari yan noong nagpachange oil ako, dati po wala naman po tumutulo.
naka isang litro na po ako nang lagay para mamaintain ko lang ang oil level ng makina
corolla toyota 1997 xl po kotse ko
may kinalaman po ba sa langis na nilagay namin po noon, shell helix 20w 50 po nilagay noon,
salamat po.
July 10th, 2010 05:22 AM #2
July 10th, 2010 06:16 AM #3
did you check first kung saan yung source ng oil leak?
agree with jick, kung oil change yung last job baka loose lang yung oil filter.
dalhin mo ulit sa pinag-change oil mo and complain about the leak.
silipin nyo kung yun nga yung problem.
- Feb 2003
- 1,038
July 10th, 2010 06:23 AM #4If those were the circumstances chances are 90% na yung suggested sayo ng mga previous posters is correct..check the tightness of the engine oil filter. It is also very important to check for the conditions of the O-ring kahit pa yan eh bago and straight from the box filter. Always inspect it and put a dab of oil in it para magmate sya ng maayos kapag ikinabit sa engine. Dapat apply correct torque lang din sa filter not too tight or too loose.
- Jul 2003
- 573
July 10th, 2010 04:32 PM #5bring the car to a service station and lift it up to look for the cause or origin of the leak.
- Jul 2010
- 8
July 10th, 2010 08:10 PM #6pumunta po ako sa shell service station kahapon, na pinag change oil lan ko last month.
okey naman po yung oil filter at yung turnilyo ng oil pan drain. wala pong tagas.
ang may tagas po sa gilid ng oil pan along the sealant.
suspetsa ko kasi, pwenersa yung pag tanggal noon ng turnilyo ng oil pan drain at di kaya namis align yung sealant ba yun between the oil pan and the engine.
kaya tumutulo po ba habang umaandar dahil sa pressure na galing sa loob ng makina
salamat po guys sa mga tumulong..
July 10th, 2010 08:49 PM #7
Kailangan patangal mo ulit oil pan linisin mabuti ang paglalagyan ng sealant. High temperature sealant na gamitin mo.
- Jul 2010
- 8
July 10th, 2010 11:26 PM #8
Xiaomi E-Car
