Originally posted by jackaroo
On the local trooper, you can only drain 3L at a time from the tranny leaving about 5L inside the plates. Refill then use the vehicle for a couple of days then drain another 3L. Repeat this until you have replaced about 9L of ATF to fully change the contents of the tranny.
The method you described above is usually done to replace transfer case fluid and other transmissions. Just see how many liters are drained from the auto tranny to determine how much to put in. May not reach the 8.6L capacity in just one drain so you'll have to do it again.
K bro I will try it and post the results. Tnx uli!
