Results 1 to 20 of 20
    Apr 2014
    Last September 2014, I change oil from 20w50 to mobil 15w40.. The Corolla 1999 2e engine runs smoother, feels lighter and quieter..
    Yesterday, I change it to mobil semi-synth 10w40 .. At first start after the change oil, the engine has a slight knocking sound .. I haven't had a thorough check at the knocking sound as of the moment because I haven't use the car since yesterdays change oil ..
    Could the thinner viscosity of 10w40 cause the slight knocking sound ?? Should I change it back to 15w40 ?? Will my engine suffer damages if I continue to use the 10w40 ??
    Oct 2013
    Baka kulang nilagay mo na oil.
    Apr 2014
    Quote Originally Posted by vvti2.0 View Post
    hindi nman cguro sir .. mga 3 and 3/4 litres ang nailagay .. may naiwan pang 1/4 sa pang apat na litro ng oil ... full nman din ang sa dipstick ..
    Aug 2013
    Quote Originally Posted by Dezaremos View Post
    sobra ito sir. less than 3 liters lang ang oil capacity ng 2E.
    regarding sa question mo, may mga oil talaga na maingay. kung saang engine oil hiyang yung engine mo, stick ka na dun.
    meron din ako ng corolla with 2E engine, hiyang naman siya sa Delo gold. kaya never na akong gumamit ng ibang oil.
    yung sakin naman, napansin ko na maingay din yung engine using mobil special compared sa toyota mineral kahit na pareho silang 20W-50 ang viscosity.
    Apr 2014
    Quote Originally Posted by innova2013 View Post
    parang hindi nman cguro sobra sir, pag check ko sa dipstick, sagad naman sa full mark .. tungkol din sa brand ng oil .. dati yung 20w50 na ibang brand, medyo maingay makina at mabigat dalhin .. nung nag change oil ako last september to mobil 15w40, gumaan ang makina at hindi na maingay .. ngayon same brand pa rin mobil pero 10w40 na, medyo may ingay ng kunti ..
    concern ko lng ay ng iba yung takbo .. parang ng stalling or jerking pag dritso mo naapakan ang accelerator, kailangan dahan dahan ang pag accelerate ...
    Oct 2013
    Ibalik mo sa dati na oil, kapag ganyan na jerking pag binibigla accelerator, sa air intake yan.
    Aug 2013
    matagal na sakin yung 2E ko bro, naka dalawang general overhaul na ako sa makinang ito (from ex-taxi to private use). sigurado akong less than 3 liters ang engine oil nito. kapag 3 liters ang nilagay, sobrang lagpas sa full mark, mga 2mm to 3mm from full mark ang lagpas.
    pero base sa explanation ng problema mo, mukhang barado ang carburetor mo o walang sa tama ang ignition timing mo.
    Correct me if I'm wrong, but you shouldn't use synthetics on an old engine, unless you have been using it since day 1, right?
    Oct 2013
    Di yan totoo, ang worst case na mangyari using fully synthetic sa old engine ay oil leak sa gaskets.
    Apr 2014
    semi synthetic lng naman ang nilagay ko ... saan po ba mag leak ?? sa head gasket mismo ?? kung magleak po, meaning pupunta din sa daanan ng coolant ??
    Jun 2011
    Pwede din natin sabihin na bka umikot ang conrod bearings mo sa sobrang nipis ng langis.Bka bumaba din ang oil pressure,pag mas malabnaw ang langis.Ung narinig mong umingay pagstart,sa connecting rod un.chka pag gumamit ka ng fully synthetic sa lumang auto,hindi lang sa gaskets magkakaron ng leak.pati sa valve seals,piston rings.Resulta,mag uusok lng naman ang tail pipe ng auto,Kaya tama ung nag suggest na gumamit ng delo gold na karaniwang ginagamit sa diesel engines.
    Oct 2009
    sa akin dati gamit ko top one syntetic .may katok akong naramdaman.
    after nun nirekomenda sa akin ng mekaniko na mag castrol nalang ako 20w50 at mag change oil nalang daw ako every 5000 kilometers.
    ayun after a few weeks nawala ung katok .at dahan dahan ng tumahimik makina.kaya nag stick na ako sa castrol.
    10w40 is definitely thinner.stick with 15w40.
    Apr 2014
    will my engine suffer damages ?? should I drain it right away and put 15w40 instead ??
    Apr 2013
    Pa check mo timing baka wala sa timing. dun ka sa may timing light para sigurado. wala sa langis yan, kahit luma makina pwede fully synthetic, pa check mo din sparkplugs baka may pundi na. wag mo muna i drain yan langis, sayang yan. wala sa langis ang problema nyan. isolate mo muna yung ibang posibilidad.
    Apr 2013
    bawasan mo lang din langis mo, wag mo sasagad sa full mark, a little below sa full mark ang ideal. sobra na nga yan langis mo kapag nasa full mark na. maghahanap talaga ng tatagasan yan langis mo kapag sobra.
    May 2009
    imo, habang tumatanda ang makina e lumalaki mga clearances ng mga bearings.... a shift to thicker oil would (or may) compensate for some issues gaya ng oil consumption, pati na rin siguro yang knocking problem ng kabayo mo sir.
    mineral or synthetic ok lang naman. ang importante e yung viscosity.
    Quote Originally Posted by saksidriver View Post
    What!!???...
    What!!???...
    a thicker oil may probably not make the knocking disappear from inside the engine.
    but it might just muffle it better than thinner oil, making it sound like the knock disappeared.
    Mar 2015
    Tama po sir innova2013, try nyo muna pa timing ulit malabnaw kasi yun oil. Baka nagbago yun timing sir
Toyota 2e knocking on Mobil 10w40 ......
