Results 1 to 4 of 4
- Nov 2008
- 35
November 27th, 2008 08:58 PM #1may tiningnan akong 2nd hand card kasi naghahanap ako ng mabibili and sabi ng kasama ko mukhang na top over haul daw.
car is nissan sentra fe 99.maingay at rinig na rinig yung pag cycle ng timing chain.
ano ba advantage at disadvantage ng na top overhaul na.inamin naman ng my ari na inayos na yung makina pero hindi sa nissan casa kundi sa kilala nilang talyer.
November 27th, 2008 09:10 PM #2
kung sa tingin nyo eh na top-overhaul na, then walk away from that car.
huwag mag madali sa pagbili
Tsikot Member Rank 2
- Sep 2006
- 1,335
November 27th, 2008 09:23 PM #3May tiningnan akong 2nd hand car kasi naghahanap ako ng mabibili and sabi ng kasama ko mukhang na top over haul daw. Sa usapang mekaniko, top overhaul means cylinder head and valve condition checking and/or repairing, and replcement of cylinder head gaskets and valve seals...
car is nissan sentra fe 99.maingay at rinig na rinig yung pag cycle ng timing chain. Timing chain is easy and cheaper to do than performing a top overhaul. Kung hindi nila inayos ang timing chain, mukhang tinipid din nila ang top overhaul.
ano ba advantage at disadvantage ng na top overhaul na. Shempre advantage ang top overhaul if properly done.
inamin naman ng my ari na inayos na yung makina pero hindi sa nissan casa kundi sa kilala nilang talyer. Mas ok sa casa shempre. Pero pwede na rin sa talyer basta marunong ang mekaniko, chaka pinalitan nila ang mga worn out parts.
Mag-sama ka nalang ng marunong na mekaniko para medyo maka-sigurado ka sa binabalak mong bilhin. Meroon tinatawag na: "REPAIR PANG BENTA LANG". Ito ang tipid na pag-rerepair.
- Sep 2007
- 215
November 29th, 2008 07:24 PM #4pag maingay yan .... get away from it ...
but i think timing chain ang problem yan ... so think you have to change the timing chain and baka yung valve lifter medyo pudpod na so that should be change too ...
it will cost you mga about 15k more or less
BANAWE AUTO SUPPLY
7120115
regy
The serpentine belt is still okay, usual consumables (air filter, oifl filter, cabin filter) got...
Ford Everest 2015
