Good Day,
Ask ko lang kung ok itong Top 1 Engine Treatment? Balak ko ilagay sa Toyota Innova J Gas. I appreciate your comment and baka may ibang brand na alam mo bukod sa nabanggit ko brand ng Engine additive. Thanks in advanced.
Good Day,
Sinubukan ko na yan. Parang wala namang noticeable na effect. Sayang lang. Ang mahal ng mga ganyan.
Mas effective pa sa akin na gumamit ng higher ron na gas (xcs).
from personal experience sa dami na din an try ko na fuel and oil additives, i think you should try or do your own personal research on this product, it name is liqui moly.. search mo sa net... german made siya, medyo mahal nga din but proven to do what it claims...
^Mukhang maganda nga yang liqui moly. Kaht yung diesel purge nia marami magandang feedback.
Fasten your seatbelt! Or else...Driven To Thrill!
Kalokahan yan mga fuel, engine additive kasama na yan sa binabayaran niyo sa gasolina and engine oil
engine treatment? yung mga products na sinasabi i-co-coat daw ang loob ng engine with some kind of slippery substance para less friction... sayang pera
basta mag change oil ka lang sa tamang interval ok na
Ang mahal na nga ng fully synthetic oil. Gagastos pa dyan sa treatment na questionable ang benefit and performance sa engine.
yung iba nga dyan tumaas lang ng konte ang presyo ng fuel galit na galit sa mga oil companies
pero willing gumastos ng hundreds of pesos para sa fuel additive na di maramdaman ang benefit
hahaha
Mukhang bihira gumagamit niyan sir, sakin na try ko na X1-R engine oil treatment, ok yung result
hindi kalokohan ang engine oil additive o fuel additive,, napapa sama lang dahil majority of these products are not really able to deliver their claims. So the mindset of those who were unfortunate to buy those non performing additives will be biased..
If you do your research and homework first, your money will be well spent
MOLYBDENUM BASED ADDITIVES - search nyo sa net regarding molybdenum additives para ma enlighten ang mga nasa dilim pa!!
*Moly has a very low coefficient of friction even in the higher heat ranges to 750 degrees F
*Major oil companies and most large industries are depending on oils and greases fortified with Moly to extend the service life and reduce maintenance on aircraft, trucks, compressors, tractors, ships and automobiles. Properly used it can double the operating life of equipment and reduce maintenance as much as 60%. Another small plus for Moly in these days of fuel prices, is that an engine treated with Moly usually obtains 10% to 25% better fuel mileage. Moly reduces friction in an engine up to 60%.
*It possesses the properties of being able to withstand extremely high load capacities (400,000 psi). It is chemically stable, has a very low coefficient of friction (0.05 to 0.09 in powder form) and has thermo-stability over 2,000°F. All of these properties are essential to reduce metal to metal contact and thereby reduce friction, heat, and wear
BORON NITRIDE OR CERAMIC BASED ADDITIVES- these additives are among the latest if not the best performing additives that has scientific data and background to back its claims...
*Temperature stability of the
ceramic particles : To +1,200 °C
*A ceramic-metal layer formed during action of an additive makes for enhances tightness of rings and a tube
*Durability of ceramic-metal layer corresponds to coaled surfaces and in under guarantee for distance of 70 000km
* Excellent Lubricating Properties due to low Coefficient of Friction at 0.15 to 0.70
Good Chemical Inertness
Electrical Insulator
Thermal Conductor (result: better heat dissipation)
High Temperature Stability, 1000o C in Air, 1400o C in Vacuum and 1800o C in Inert gas
Low Thermal Expansion
Low Dielectric Constant
High Load bearing properties
Non-Wetting: hBN is not wetted by Glasses, Salts and (most) metals, therefore it provides strong resistance to chemical attack Easy Machineability (in hot pressed state). Complex shapes can be machined from hot pressed structure.
one treatment will last you around 40,000kms to 70,000 kms... boron nitride is virtually indestructible once it binds into your engine metal parts
ano uli?
duralube?
sige bigyan mo ako ng sample
after 6 months malaman ko kung may benefit... then i pay
maganda nga daw po yun... sbi nung friend ko... nabutas daw ang water hose nya at nauubos ang tubig then he was still able to run his fx from makati to fairview with a.c. loaded with passengers with no changes in temperature....
i also put one on my tranny mas magaang po tumakbo ang car ko...
Sige, let's try it on your car, alisan natin tubig and engine oil tapos lagyan lang natin ng duralube then gamitin natin tutal yun naman ang pinapakita sa infomercial nila eh.Originally Posted by glenn manikis
