Results 1 to 10 of 70
- Apr 2010
- 71
August 12th, 2013 01:44 PM #1Hello tsikoteers, just wanna know if the starter can be a major reason of cold start problem? Sorry if you find this a non-sense question, the reason I asked this because our car is only experiencing hard starting at first start, but when the car finally starts, wala na pong problema sa maghapon even if you on and off the engine, one click na lang.
- Carb was already properly overhauled in kamuning and replaced complete set of carb kit not just the o-rings
- OEM magnetic fuel valve was also replaced
- NGK plugs were just replaced last May
- Fuel filter is also new.
Is there any other things to consider to finally solve a cold start issue?
Ride is honda 92 / PH12 engine. Any response will be highly appreciated. TIA
- Jul 2011
- 1,711
August 12th, 2013 02:15 PM #2before po nyo start ang engine paki check po ung engine oil ninyo (mas maganda po kung nag overnight parking kayo then sa umaga para nag settle down ung langis).
kung malapot po ang langis need po yan i-circulate kaya po maingay ang cold start.
Possible naman din po na malapit ng bumigay ang battery ninyo, pa-check nyo na din po ito sa mga battery shops normally libre naman ang pag check nila.
August 12th, 2013 02:19 PM #3
- Apr 2010
- 71
August 12th, 2013 03:09 PM #4
August 12th, 2013 03:24 PM #5
Tsikot Member Rank 2
- Jan 2008
- 4,726
August 12th, 2013 03:35 PM #6ano ba gamit nyan ph12 manual fuel pump or electronic?? yan muna check mo
- Jul 2011
- 1,711
August 12th, 2013 04:01 PM #7nung magpalit ka ba ng fuel filter na-drain din ba ung fuel tank mo?
possible din na madumi ung fuel sa loob ng tank, tignan mo din ung fuel cap kung meron moist.
try mo magpakarga sa ibang gas station ung alam mong hindi binabaha
- Jul 2011
- 1,711
- Apr 2010
- 71
August 12th, 2013 06:25 PM #9
- Apr 2009
- 429
August 12th, 2013 06:53 PM #10Did your hard-1st-startup-in-the-morning happened after you had your carburetor overhauled? If yes, your mechanic must have messed up the adjustment of the fuel float or the replacement float he installed (fr the new repair kit) has a different setting. Straying away from the factory-set fuel float adjustment will make your gasoline evaporate more than usual (in the carb fuel chamber) during overnight parking. This will make the carb fuel-starved in the morning, hence, the hard 1st start-up
My Dongfeng Nanobox - a case study of an electric...
