Results 1 to 4 of 4
    Feb 2012
    sir good day po,newbie lang po ako dito at sa car,nabile ko ung honda civic ng naka direct na ung on nga fan sa radiator,wala pong thermostat,after ko bumile ng thermostat bago po umandar ung fan eh nasa 3/4 na,kaya ginwa ko binalik ko n lang ulet sa direct,bakit po ba ganun?salamat po
    Jun 2006
    Pa check mo sa reputable shop or mechanic, possible problems:
    1. defective thermoswitch, this device tells your fan when to start
    2. wrong thermostat, baka masyadong mataas ang setting
    3. the fan itself might be malfunctioning
    Feb 2012
    sir ano pong setting,my iba pa po bang size nun,sa mechanic ko din pinakabit un,tatpos after na nakita niya na ganun suggest niya sa akin ibalik ko na lang ulet sa direkta,sa fan po ok naman po kapag naka direkta na natakbo naman siya un nga lang simula sa start ng engine kahit hindi pa mainit ung radiator,
    Yung fan kahit tumatakbo, if its not moving enough air (e.g. luma na motor), over heat pa din
    Other things to consider:
    1. Dumi sa loob ng radiator. Have it opened (babaklasin) and cleaned by rodding (tutusukin ng bakal yung passages).
    2. Dirty water pump which is slowing the circulation speed of the water.
    It's still the best to have a thermostat, thermo switch operated fan (mura lang thermoswitch), and a good working cooling system. Just invest a little in finding the problem and your car will give you years of service and good fuel economy.
Thermostat working at 3/4 sa guage
