Originally Posted by
oj88
No, he means that the temp gauge stays at the same place even if the engine temp varies within its nominal operating temp. It's non-linear.
For most vehicles, the temp gauge stays put in its "normal operating temp" position if the actual coolant temp is between 85°C to 110°C or whereabouts. They made it such so that the driver doesn't panic when the non-graduated temp gauge starts swinging up and down during the course of the trip.
Depending on the vehicle, the temp gauge would only start creeping into the Hot range when the coolant temp gets past the operating temp threshold set inside the ECM. My guess would be 115-120°C onward. At this point, the gauge moves at an exponential rate.
