Results 21 to 30 of 49
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 10th, 2006 12:22 PM #22
- 299
March 10th, 2006 01:18 PM #23pwede ba lagyan ng wrap ang stock na headers? masikip masyado? useless?
March 10th, 2006 03:26 PM #24Originally Posted by sequoia
March 10th, 2006 03:39 PM #25
sabi ko na nga ba parang familiar ung thread. hehehe
Originally Posted by albert_bLast edited by flakez; March 11th, 2006 at 03:13 PM.
- Nov 2003
- 3,849
May 26th, 2007 11:05 PM #27
Guys, I am planning to install thermal wrap for my Exalta STA. Masyado kasi mainit ang engine bay, kawawa yung aux, alternator and mga hoses... makakatulong ba ang thermal wrap sa paglessen ng init? Pros and Cons?
Please let me know if it's worth it.. I am going to pa-install kung okay ang comments nyo..
Thanks!
Tsikot Member Rank 3
- Oct 2006
- 1,069
May 26th, 2007 11:20 PM #28
May 26th, 2007 11:38 PM #30
Pros - yes, it will dramatically cool down your engine bay.
Cons - what Si06 said. Pero if you're still using your stock iron headers, they might survive... oops... scratch that... stock iron exhaust manifolds might eat themselves up more quickly than stainless headers...
EDIT2: yeah... that article explained it...
Personally, yeah, get high-temp hoses, like Si06 said, and you could also insulate the engine bay electricals instead of the headers...
Or you could try cerami-coating your headers... ghetto style... take off your header, wash out all the deposits in there with a strong solvent, some high-pressure water and detergent and an air hose... if you can get something in there to scrape it out (like a steel brush), even better... then fill the header with high-temp paint (those 1000 degree paints you see at hardware stores for burners)... swirl it around in there to get a nice even coating, then drain and let dry.
I don't guarantee the coating won't flake off and get ingested into your engine when you start it, though... there's a vacuum when you start the engine... which is why flaky cats have killed QR25 engines in the US... but it should do the same job that header wrap does.Last edited by niky; May 26th, 2007 at 11:49 PM.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
