Results 1 to 19 of 19
  1. seven26ers Guest
    meron ba kayo alam na shop na nag supply/install ng surplus engines? pina check ko kasi yun makina ng car ko and sabi nagbo blow by na raw and it needs replacement of piston rings (cost is about 17k). but i heard meron daw mas cheaper na option, that is replace the engine with a surplus. please help naman. thanks!!!
    para sa anong kotse
    Madami pong nagbebenta ni sa maga surplusan sa Banawe. Mamili na lang po kayo. Goodluck.
    seven26ers, ano pong car ninyo? para at least we can narrow down the options for our car and provide you with a better quotation.
    as sir roydok pointed out, marami po sa banawe na surplus engines....meron din ata sa evangelista sa makati :mrgreen:
    sa blumentritt dumaan ako kanina dami pala don...
    Jan 1970
    Guys ano kaya ang magandang replacement ng 2e engine para sa 95 Toyota corolla... How much it will cost including labor at gaano katagal gawin yun .... One last thing mga ilang years kaya ang useful life nitong surplus engines.....
    Many thanks....
    change engine na yan pag blow by na engine. . mas magastos pag paayusin mo pa db
    Quote Originally Posted by Jolam143
    Many thanks....
    TOYOTA 20Valve!!!! :twisted: Meron nito sa ER Cinco in Cubao, di ko lang alam kung magkano
    Jan 1970
    pajerokid.... unfortunately andito ako sa mindanao.... pero oks lang if you could give me contact number nitong ER Cinco... it would be greatly appreciated thanks....:wink:
    4AGE ata twag dun sa engine na un . hehehe
    Mar 2003
    that's 4age 20V blacktop mas maganda kesa sa silver.. :D
    but the 4AGE 20V silver top is more common and cheaper too. Power isn't that bad, usually between 135 to 150hp depending on the type of engine you got.
    Quote Originally Posted by odell
    ang maganda lang kasi sa overhaul..sigurado ka
    na brandnew yung ilalagay..kung may magaling
    kang mechanic to do the overhaul
    sa surplus engine tyambahan lang talaga..hindi mo alam
    kung ok pa talaga yung motor
    Magreplacement piston rings ka nalang. Ask mo si Pajerokid. Mukhang magaling ang mechanic niya. Kapag nagblow- by na rin engine ko, dun ako magpapagawa. Balita ko lakas ng Pajero niya ngayon...parang naka Twin Turbo...di ba PK? :mrgreen:
    blow by din ang engine ko dati... ang ginawa sa machine shop ay ni-rebore ang cylinder tapos nilagyan ng bagong sleeve. Binili kong sleeve ay Federal Mogul. Tapos palit lang ng piston ring (maintained standard size). That was 4 years ago...malakas pa din ang fx ko...pinagisipan ko din na bumili na lang ng surplus pero sabi ng mekaniko ay tsambahan din kung tatagal or hindi ang makukuha ko....syanga pala nasa mekaniko din ang buhay ng engine mo..kung hindi expert magbaba ng makina ay sayang din..
    Mar 2003
    hmm..compresson test mo muna.. leak down test.. so that lam mo if the engine is running efficiently.. after that obserbahan mo muna ung makina..
    isa isa lalabas prob. niyan kase surplus engine di maiiwasaN..
    tiyaga ang kailangan dito.. pero worth it pag naayos mo na..
    Jun 2003
    Mga kapatid,
    My second hand pajero also suffers from a blow by engine. Right now ay nasa casa for compression testing (for further confirmation).
    Maari bang malaman ang inyong tested mechanics na maraming alam sa overhaul ng Pajero 4d56tdic? Sana malapit lang dito sa West Ave, QC.
    Any repair shop that you trust in Banawe that specialize in diesel engines and Pajeros?
    Naghahanda lang ako baka sakali kailangan ang overhaul.
    Salamat ng marami
    Oy DJERMS, twin turbo ka jan?! hehehehe.
    Yung sakin pinalitan ng replacement piston rings and sleeve. ok naman. total gastos is mga 20k.
    Aug 2009
    Quote Originally Posted by pajerokid View Post
    PajeroKid baka pwde mk matulungan..gusto ko sana i-restore ang pajero ko model '90. Ano marerekomenda mo..gusto ko sana ipa-turbo ang engine..tas papalitan ko rin ilalim..meron ka ba pix ng mga restored na lumang pajero
    matsala
surplus engine replacement
