Results 11 to 19 of 19
- Mar 2003
- 91
June 9th, 2003 10:36 AM #12
but the 4AGE 20V silver top is more common and cheaper too. Power isn't that bad, usually between 135 to 150hp depending on the type of engine you got.
June 9th, 2003 01:17 PM #13Originally Posted by odell
na brandnew yung ilalagay..kung may magaling
kang mechanic to do the overhaul
sa surplus engine tyambahan lang talaga..hindi mo alam
kung ok pa talaga yung motor
June 12th, 2003 11:00 AM #14
Magreplacement piston rings ka nalang. Ask mo si Pajerokid. Mukhang magaling ang mechanic niya. Kapag nagblow- by na rin engine ko, dun ako magpapagawa. Balita ko lakas ng Pajero niya ngayon...parang naka Twin Turbo...di ba PK? :mrgreen:
June 12th, 2003 12:43 PM #15
blow by din ang engine ko dati... ang ginawa sa machine shop ay ni-rebore ang cylinder tapos nilagyan ng bagong sleeve. Binili kong sleeve ay Federal Mogul. Tapos palit lang ng piston ring (maintained standard size). That was 4 years ago...malakas pa din ang fx ko...pinagisipan ko din na bumili na lang ng surplus pero sabi ng mekaniko ay tsambahan din kung tatagal or hindi ang makukuha ko....syanga pala nasa mekaniko din ang buhay ng engine mo..kung hindi expert magbaba ng makina ay sayang din..
- Mar 2003
- 91
June 21st, 2003 01:46 PM #16hmm..compresson test mo muna.. leak down test.. so that lam mo if the engine is running efficiently.. after that obserbahan mo muna ung makina..
isa isa lalabas prob. niyan kase surplus engine di maiiwasaN..
tiyaga ang kailangan dito.. pero worth it pag naayos mo na..
- Jun 2003
- 16
July 5th, 2003 08:41 AM #17Mga kapatid,
My second hand pajero also suffers from a blow by engine. Right now ay nasa casa for compression testing (for further confirmation).
Maari bang malaman ang inyong tested mechanics na maraming alam sa overhaul ng Pajero 4d56tdic? Sana malapit lang dito sa West Ave, QC.
Any repair shop that you trust in Banawe that specialize in diesel engines and Pajeros?
Naghahanda lang ako baka sakali kailangan ang overhaul.
Salamat ng marami
July 5th, 2003 11:00 AM #18
Oy DJERMS, twin turbo ka jan?! hehehehe.
Yung sakin pinalitan ng replacement piston rings and sleeve. ok naman. total gastos is mga 20k.
- Aug 2009
- 1
August 28th, 2009 05:33 PM #19
