Page 8 of 9 FirstFirst ... 456789 LastLast
Results 141 to 160 of 174
    Mar 2004
    #141
    I got my car back. Thanks everyone for the advice, quiet na ulit engine pero bakit feeling ko naging matagtag car ko or I'm just being paranoid? Pina check ko tire pressure tama naman
    Mechanic swapped your shocks ...
    Jun 2013
    #142
    Ganun na nga hahaha. Kasi ganda ganda ng takbo ng car ko tapos out of nowhere feeling ko sasabog engine. So traumatic. I've been driving since I was 16, first time to experience that
    Kasi yung old cars may signs like iingay or something or pag shocks sira matagtag.
    May timing belt ba car ko? Yan kinakatakutan ko din masira
    If its a Toyota, its an easy fix. 👍👍👍
    Pag sa ibang brand yan nangyari, tatawagin yan na sirain.
    #143
    I'm seriously thinking that but my car is 9 na rin naman, old na rin shocks pero 41k kms nga lang. I know my car, super smooth yun e ngayon parang mas matagtag pa sa 10th gen ko na may leak na talaga shocks
    Sent from my SM-M127F using Tapatalk
    how can they have time to swap shocks
    March 16
    Yun lang hahaha
    I had an anxiety attack this morning. I couldn't breathe Feeling ko talaga lemon car ko and I need to dispose of this soon pero hindi talaga ako bibilhan ng bago e jobless ako [emoji24]
    Anyway, thanks to the Tsikot community kasi yung 40k PMS ko na P18k was cut in half! Kung madadala ko lang car ko sa QC baka less than P10k lang magastos ko for the coil ignition and valve cover
    march 17
    Btw, bakit kaya no symptom at all yung sa ignition coil ko? Also, hindi ko talaga matanggap na at 41k, 9 yrs old bumigay na hehe
    #145
    March 16
    march 17
    March 15, 9 am pinick up then they messaged me today (Mar 17) lunch time na ready na unit.
    I should have gotten it March 16 but I only gave them go signal nung March 16 to proceed with the repair and PMS. One day daw kasi to order parts
    Ano kaya cause bakit bigla naging matagtag [emoji24]
    March 15, 9 am pinick up then they messaged me lunch time na ready na unit.
    I should have gotten it yesterday but I only gave them go signal nung March 16 to proceed with the repair and PMS. One day daw kasi to order parts
    yun nga
    so hindi counted ang march 15 dahil 16 ka nag go ahead
    march 15 your car was just parked at the casa
    they started working on your car yesterday (palit ignition coils, valve cover gasket, change oil etc) and you got your car today
    you think they can squeeze in the time to remove your shocks and install someone else's old shocks?
    di madaling trabaho magpalit ng shocks
    tsaka meron sila ibang cars to attend to
    Jan 2008
    #147
    Baka naman matigas lang gulong.. nag add ng air ang tech..
    Pwede din nung pag lift, fully extended ang shocks pwede mag cause ng pag tigas yan pag luma na.. di na bumalik sa dati
    Mar 2004
    #148
    Possible they left your vehicle on the lifter for too long ... or worse overnight ... solution before was to "compress" the shocks while driving ... you'll have to figure out creative ways of doing this safely ...
    Feb 2009
    #149
    leaving the car lifted on a hoist does not cause the ride quality change. if it had active suspension, it has to be switched off first to prevent the ride height control from extending and contracting the actuators repeatedly
    altis does not have active suspension like the mid 90s sports and luxury editions with TEMS- toyota electronically modulated suspension
    Mar 2004
    #150
    It does and have experienced it with Hondas ...
    Feb 2009
    #151
    it would show on the dashboard or instrument panel. during KOEO (key on engine off) check mode, all the warning lights go on to check mode, all of them light up. some turn off automatic from the delay timer, some when the conditions are met to extinguish the warning light
    #152
    if you are inclined,
    do some forensic mechanics.
    inspect the nuts and bolts on them shocks. after being there for 9 years, i expect them to be dull or dirty on the surface.
    are they dull and dirty, or are there bright spots, suggestive of recent manipulation?
    after this latest issue Cathy already convinced herself her car is a lemon
    kahit naayos na car niya she expects another issue to arise
    kakabahan na siya gamitin ung car
    psychological na ito
    #154
    kakabahan na siya idrive ung car
    you're probably right.
    once you are convinced your car is a lemon,
    every little creak will be cause for concern, even when in truth, 'there's nuthin' to be worried about' .
    sell it nah. you'll never feel comfortable again, driving her.
    heh heh heh.
    I remember many moons ago, people were saying the gen1 CRV cant be put on a car lift for too long since masisira yun spring.
    heh heh heh.
    yup she should sell it nalang
    wala na eh
    it's like nag fall out of love na siya sa asawa
    mag separate nalang sila
    #157
    duda ko nasira ang shock mount
    ganyan nangyari sakin back in december, medyo natagalan naka jack stand yun fronts
    ayun namulot ako bearings sa garage [emoji23][emoji1787]
    Sent from my 22021211RG using Tsikot Forums mobile app
    Mar 2004
    #158
    Yes that is the case of honda CR-Vs before (not sure now) ... but the "expert" from abroad is saying it doesn't happen and if it does, an error should light up ... so I guess it doesn't exist here ... we are just imagining it ...
    The shocks are just stretched, they're not really damaged ... you just need to "reseat" them by compressing the shocks ... one method is to find a steep driveway or incline and drive diagonally towards the incline to "compress" the shock one by one ... or find a ramp a drive fast so the car jumps and lands hard ...
    #159
    That's the first thing I did, pinacheck ko yung air, perfect naman
    OH NO! Naalala ko tuloy nung na overspray ng casa yung car ko and I insisted na ayusin nila kapalpakan nila
    My car is not that hi tech
    I will post the report of the casa, they found nothing else to repair. Passed lahat sa inspection. Nakalagay they tightened the nuts and bolts, baka dapat hindi na lang nila ginalaw e
    That's what I told the SA nga kung reliable pa ba car ko e I have to go home to Laguna more frequently pa naman
    #160
    Sakit ata ng Honda? hehe
    wala na eh
    If I had a job I would, if I get a windfall of money, that's the first thing I will do nga. Saka diba dito sa Tsikot may mga hindi gusto ang CVT? Parang disposable car ata or something?
    Sana naman hindi sinira ng casa
    I really hope so. How about if I don't brake na sa humps. How about yung humps na pangit/steep in BGC sa may mind museum?
Sudden Rough Idling/Car Shaking
