definitely skip the decarbonizing part. most likely this is the spray can type. it has little to no effect and to get that result 1 application probably is not going to be enough. real engine decarbonizing is through walnut blasting. if you use good fuel and change oil often this carbon buildup is greatly minimized anyhow.
Thanks I will have it removed
how did the service advisor know there is carbon build up in the combustion chambers? is he a fengshui fortune teller? any rational knowledgeable technician would investigate the condition of the chambers using a
high definition videoscope looking directly into the combustion chambers or use a digital storage oscilloscope and analyze the secondary ignition waveform when the engine is running. otherwise, he is selling false sense of performance improvement. do not buy unnecessary service unless there are tests done and there are proofs or digital printout from a diagnostic tool or equipment
It seems like the new SA is NOT happy about me removing some items kasi 2021 pa daw since my last change oil [emoji35] I said I follow every 5k and that takes me a long time talaga.
I have to remember to buy coolant, I will do it myself. Then I will ask for old parts and the excess oil
