Guys, want to know what are the best way to start and drive your car to achieve low fuel consumption.?
First,
Make the sign of the cross
Then
Pray you won't have SUA[emoji1]
Check ang kabyo kung naka N. Then half na key stroke para makita kung naka handbreak and kung may error. Kung wala start na. Then check ang mga mirror, pakingan ang engine. Seat belt then takbo na.
Ang alam ko sa diesel midyo need mo talaga pa initin bago e takbo.. pero kung gas naman need pa ba? Or even less than a minute e pwd na e takbo? Ano posible effect sa engine kung pag start e takbo na accelerate na agad.
in the morning, I press the brake pedal with my hand and press start button. Car starts rev at 1500rpm then eventually settles at 750 after around a minute or two (depends on ambient temp).
Go around the car, open the gates, check for puppies and kittens under the car. Spray with water when one is present. By that time the engine would've warmed up and I'm ready to go.
According to my manual..yung picture..under eco driving... Di ko nmn nasusunod... Kasi after ko start 1500 RPM then wait ako ilang minutes until bumaba ng 700rpm..
Regular PMS and remove clutter (which have weight), also drive earlier, while we are still sleeping so you will not waste fuel in traffic.
