Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    I was wondering where it would be cheaper to buy spark plugs. I usually see some of the fancy ones over at ace hardware or the DIY shop but I can imagine they wouldn't sell them at a good price. Suggestions on which shops are recommend would be great!
    Denso iridium
    Bosch multi-electrode +4
    Bosch regular platinum
    Splitfire
    NGK iridium IX
    And based on your own personal experiences, which for you is the best?
    ako i avoid small auto supplies dahil baka fake.
    i usually get them at reputable shops like Servitek or sa Shell.
    Jul 2011
    para iwas fake.
    its either sa casa for OEM plugs,
    bosch outlets for orig bosch plugs - check bosch site sa net, makikita mo dun mga official distributor dito sa pinas.
    and NGK shop mismo sa banawe, for NGK naman.
    Jun 2012
    Quote Originally Posted by 1D4LV View Post
    Bossing, paano malalaman pag fake ang spark plug?
    Quote Originally Posted by 7138 View Post
    para iwas fake.
    saan yung NGK shop sa Banawe?
    For Denso, sa Denso mismo or sa Riken Motors in Masangkay. Bought the iridium plugs of the innova from Riken. 520 each
    Sep 2013
    TS, personally i don't buy the above mentioned items. Besides it's expensive, it does serves the same purpose as the regular spark plugs IMO. I just buy regular sparks only, clean the spark plug tips every time change oil. Below is the pictures taken before cleaning it. DIY by soaking it in coke mixed with salt, let it stays for overnight then use steel brush to clean the spark plugs tip, adjust if necessary. this park plug has been in the engine for 20k mileage, still in tip top shape condition huh!!! spark-1.jpg
    Jul 2011
    Quote Originally Posted by kimbon View Post
    sulit naman sya kasi mas matagal ang pagitan ng palitan. sa honda jazz/fit GE iridium na nakakabit, 100K Km ang recommended change interval. malaking tulong sya kasi mahirap palitan ang spark plugs ng jazz, kailangan pa tanggalin ang cowl cover para maabot ung spark plugs.
    Jul 2011
    Along banawe street lang mismo sir cb, if your coming from q.ave, nasa left side sya, may NGK sign board sya sa labas, closed yung shop, di-aircon, tinted yung doors and windows.
    Quote Originally Posted by confused shoes View Post
    here you go..
    Distinguishing fake ngk spark plug
    Hey man, how do you find the iridium plugs? Do they last as long as the platinum ones?
    Back in the mid 90's, I shifted from your normal copper plugs to splitfire. After 5 years, I went back to normal copper plugs and just changed my plugs every 10,000 - 15,000. There are too many conflicting papers and reports on the benefits of having a normal copper plug versus the multi-electrode plug wherein the copper plug corrodes fast but the spark is better whereas the multi-electrode plugs last longer but have a smaller spark. I don't really know what to believe so I was thinking of trying again the platinum / iridium plugs.
    What brand are those you're using? When you say adjust, are you referring to the gapping?
    Quote Originally Posted by K.I.L.L. View Post
    So far so good. I shifted to iridium so I don't need to replace the copper plugs every 5-10k km. The Denso Iridium Power spark plugs are said to last 30k km.
    Sent from my Nexus 5 using Tsikot Forums mobile app
    Jul 2006
    Where is the AFTER cleaning picture?
    BTT:
    I was never a fan of "fancy" sparkplugs. I just buy what is recommended by the manufacturer as per the owners handbook. Beru or Bosch for the europeans in my garage, and Nippondenso / NGK for our one and only japonesa.
    :D
    Jul 2011
    Please correct me if I'm wrong,
    ang iridium every 100k ang palit
    sent via LaTE Network
    BTT:
    :D
    naka specify na din minsan sa owners manual yung ordinary and iridium plugs equivalent. sa mga older cars yata puro copper plugs lang nakalagay.
    Quote Originally Posted by Manilablock View Post
    sa factory installed iridium plugs, 100k km replacement. but for aftermarket iridium plugs, way lower. cause iba yata spec nung OEM plugs.
    DENSO SPARK PLUGS - Basic Knowledge
    Jul 2011
    Thanks for the info, so pag ung iridium plug ay tapered ung tip hindi ito tatagal ng 100k.
    Jul 2006
    Yup, mostly copper electrodes. The manufacturers manual usually state 3 brands of choice, in my case its either Bosch, Beru, or Champion.
    i think it has something to do with the tip. 0.7mm yung factory installed long life plugs, while 0.4mm yung mga aftermarket plugs. I think the platinum tip also helps extending the life.
    Aug 2012
    the Denso Iridium Tough series is the long life type.. up to 100,000 km before replacement
    you can check the Iridium Power and Iridium Tough part numbers for Philippine vehicles here: http://www.globaldenso.com/en/produc...ippines_4w.zip
    Quote Originally Posted by red_one View Post
    when i inquired with Riken Motor Sales, they only have Iridium Power in stock. they dont have any Iridium Tough
Spark plugs - places to buy from
