Ano magandang brand?
Honda na spark plug or ibang klase? Honda na iridium ay nasa 649 isa.
iridium kasi daw ang stock nang Jazz...
yung sa casa kasi Php 649... Mas maganda ba ibang brand?
IIRC Iridiums are replaced every 100k kms. IMO ok na ang casa price at least medyo sure na compatible.
kakapalit ko lang.... NGK Iridium. Stock sa Altis.
850 pesos each. Casa, Toyota Alabang.
OEM spec Iridium will last for 100,000 km. Para sure, bili ka na lang sa casa.
Wag kang bibili ng local Denso Iridium (IK20) dahil for 20,000 km lang ito. Hindi available locally ang Denso Long Life Iridium (OEM spec) na up to 100,000 km.
Sa NGK, you can get NGK Iridium IX na up to 80,000 km or NGK Laser Iridium na up to 160,000 km.
i disagree with this, sa owners manual natin ang nakaindicate lang dun is yung regular plugs lang ng NGK and denso,
my car too is a honda jazz, and currently it uses regular plugs. wala naman pugak.
been reading fitfreak.com for a long time and ang usual suspect sa kanila kapag ganyan is yung coil packs.
have it checked.
Nyaahh... Kung hindi naman stock sa car ang iridium, wala naman yan dapat effect kung palitan mo ng ordinary.
most new cars today are equipped with iridium plugs for longevity. But you can always buy them outside as long as you know the irdium-equivalent of your stock plugs. I still prefer Denso and NGK iridiums. You can always access their website if you want to know their models for your engine. Since they are long lasting, What i do is rotate them every 5-10k km mileage to prevent their treads seizing up in the cylinder head.....
pa double check mo lang yung ignition coil kung saan nag susupply ng current papunta sa spark plug. baka ito ang cause ng pag pukag. sa mga lumang car ang isa sa mga cause ng pagpukag ay current galing sa ignition coil, spark plug or contact point pero sa modern car ay wala na ang contact point kundi electronic na to. Hope it helps.
they check it also yung ICM ( ignition coil ), reset nang computer then noong pinalitan nila nang spark plug na iridium nawala ang pugak. So far wala na ako nararamdaman ngayon dahil pinahiram muna nila ako nang iridium na spark plug next for observation. Pero next week need ko na ibalik sa kanila.
Out of specs daw yung ordinary na spark plug na kinabit. Ok sa simula kasi bago ( pinalitan sya last sept 2014 pa ) pero pagtagal daw magkakaproblema kasi out of specs sya.
Kaso eto nakakatawa... Yung spark plug price ni greenhills ay Php 1,280 ang isa at yung sa cainta ay Php 612 ang isa ( lumang model nang iridium ang sa cainta )
the only difference in specs would probably would be the heat range of plugs siguro... bawat model ng engine kasi ng vehicle meh specific heat range...
if the first 3 grooves ng thread is blacked, its ok, anything less than or more that (less than 2 grooves/ mroe than 3 grooves blacked) eh detrimental sa life and performance ng plugs...
ito probably and sinasabi na out of specs that eventually will lead to failure...
