Results 1 to 10 of 18
March 17th, 2009 10:06 PM #1
During my PM, i would normally replace the spark plugs. During my last PM after only less than 3000 km run, the spark plugs are all burned as in black with brown in the tip (parang corrosion) my mechanic changed it with a slightly used but it's still sparkling clean. Now after about 2000 kms run, all are burned again with even one of the plugs, loosing the electrode tip ba yun (not the bent portion). Now i replaced it with a brand new Bosch Super 4.
I knew it's not normal caus emy other cars would even last 20K km before i would cahnge spark plugs. Car is CRV 2000 model.
Question is, what would have caused my unusual burning of spark plug?
TIA
March 17th, 2009 10:23 PM #2
Try checking and comparing the pictures and diagnosis of the sparkplugs at this website:
http://www.autohausaz.com/html/spark...lug-wires.html
March 18th, 2009 11:39 AM #3
thanks ghost. very informative that i even bookmarked the site. however, yung problem ng spark plug #3 ko isn't in the pics kc nawala totally yung center electrode when i pulled it out. the other 3 are normal as per pic 1 & 2.
where would you categorize kay yung #3, under melting or cracking as in pic 13 & 14 or it's a totally different story? thanks again.
March 18th, 2009 12:00 PM #4
I might be tempted to say it might be #13 or even #17 from your initial description.
March 18th, 2009 12:54 PM #5
This link may be of help to you. http://www.answerbag.com/q_view/710848
March 18th, 2009 03:28 PM #6
are you using the correct type of sparkplugs?
although pwede yung bkr5e and bkr6 (ngk) sa b20z engine ng crv mo, the correct type is prefixed ZFRxxx. may subtle differences sila. i tried bkr5 sa crv ko nun medyo malakas yung amoy gas from the tailpipe when idling. lumakas din sa gas ng konti.
switched back to casa spec zfr ngks ok na ulit.
March 18th, 2009 05:58 PM #7
thanks volts, observe ko muna yung super 4 ng bosch na kinabit ko since bago pa naman. check ko condition after 1000km. if it's still bad, i'll try the ngk type u've mention.
ghost, sana nga 17 since it was a used set of spark plugs then and beside kung 13, dapat lahat ng spark plugs would have been affected not specific on #3 only. let's see how it goes since ang recommendation sa 17 is change spark plugs. do u think i need to go back to unleaded since i've changed fuel to xcs?
i'll observe lang muna & see how it goes.
March 30th, 2009 09:56 AM #8
update ko lang for the closure. checked my spark plugs yesterday, all is well naman after 1K+ km run. normal carbon on the tips kaya cleaned it with kerosene & brush. so far gas consumption is relatively normal as well.
i'll just do frequent cleaning and see how long this sets of spark plug would last.
December 6th, 2010 01:40 PM #9
hi mga sir. just wanted to ask assistance if my spark plugs are still good to use.. i checked the website for reference and i believe that engine good in regards sa sparkplug. but i also want to know if my plugs are still good for the next 15k run..
December 6th, 2010 02:19 PM #10
I replace my spark plugs regularly when I change oil at 5,000 km.
Just regular Denso or NGK spark plugs as per the car owner's manual. Cost for new plugs are not so expensive and if changed regularly can be recovered in terms of proper engine performance and mileage for the vehicle.
Xiaomi E-Car
