Results 1 to 10 of 10
March 4th, 2006 07:15 AM #1
From what i've heard and read replacing your old worn out engine mounts to a new or aftermarket ones greatly increases torque and eliminates wheel hop and engine movement. Just wanna get your feedbacks, violent reactions and expert opinions.
March 4th, 2006 07:29 AM #2
it does add a bit rougher idling though, since the mount is stiffer than usual, transmitting the engine idling movement through to the chassis instead of the engine mount soaking/damping the motion. :D
March 4th, 2006 07:53 AM #3
plus greater fatigue loading on the mounting points. think of it this way: if you remove the springs and shock absorbers from the suspension, how long do you think the suspension will last? that is the same situation as with the engine with solid mounts.
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 4th, 2006 10:40 AM #4it won't increase torque. wala syang play so all of the vibrations you feel through the body. if you don't race don't do it.
March 4th, 2006 08:59 PM #5
engines mount acts as buffers/shock absorber for your drivetrain. using solid mounts is just like extending the chassis mounts.
BANNED BANNED BANNED
- 3,790
March 4th, 2006 09:39 PM #6AFAIK even real racers don't use solid mounts but rather engine mounts with stiffer rubber...yung lang low budget racers and gumagamit ng solid mounts....kasi mas mura gumawa nuon kaysa gumamit ng maganda as mas matigas na rubber mounts.
March 5th, 2006 09:26 AM #7
Thanks guys! Some of my buddy's kasi had some shop replaced there engine mounts with stiffer rubbers kagaya nang na mention ni wildthing. I think this is also the same as the engine mount inserts that i'm planning to buy. But i'm not into racing thats why i'm having second thoughts.
- Nov 2003
- 3,849
March 5th, 2006 10:16 PM #9
lalakas ang vibration sa loob ng car mo. there is a store along sumulong hightway going up antipolo nasa left side. they use used tire rubber. matibay daw ito but on the stiffer side siya..
March 5th, 2006 10:31 PM #10
Actually, an easy way to stiffen up and minimize wheel hop is to insert rubber or polyurethane pieces in the open spaces in the stock mounts. There are polyurethame kits available for most cars from the US.
