Results 1 to 8 of 8
February 15th, 2010 11:52 AM #1
napansin ko parang may smoke sa may engine, so pina check ko sa mechanic, nung tingnan nya medyo sunog na ung isang spark plug, sabi nya baka sira na daw ung piston ring, so kailangan na daw dukutin ung makina. mga 7k daw aabutin. corolla 2e ung engine ko. is my mechanic right. thanks
- Jan 2005
- 445
February 16th, 2010 09:03 AM #2Baka naman meron lang singaw ang tabutso. Napapansin mo ba kung nagbabawas ng langis o tubig? Ung spark plug di naman un nasususnog baka ma carbon lang baka mali lang heat range.
BANNED BANNED BANNED
- Jul 2003
- 2,267
February 16th, 2010 09:21 AM #3palitan mo yang mekaniko mo. manloloko yan.
kahit pa papalitin ang piston ring, ndi yan magiging cause ng usok sa engine bay. it's either may singaw ang exhaust or may fluid (like oil) leak na pumapatak sa maiinit ng surface.
ipa-compression test mo yung engine mo para malamn mo kung kelangan na palitan ang piston ring.
February 16th, 2010 10:29 AM #4
kung bluish ang emission, oily ang tail pipe, oily ang sparkplug at nagbabawas ng oil pwede ngang piston ring. hingi ka ng 2nd opinion ng ibang mechanic.
- Apr 2008
- 537
February 16th, 2010 06:05 PM #5
February 17th, 2010 12:38 AM #6
may napansin nga ako carbon dun sa may spark plug, pero papa compression test ko muna, meron ba sa servitek ng test na to
- Jan 2005
- 445
February 17th, 2010 09:28 AM #7Pag may carbon at hindi naman nakain ng langis makina mo, maaring in correct heat range ang spark plug mo, kailangan mo ng spark plug na 1 step higher. Maari din na too rich ung fuel mo, kailangan mo adjust air-fuel mixture.
Or di ka lagi ka sa stop and go traffic, pag ganun byahe mo ng highway for 30 minutes, mapapansin mo lilinis ang spark plugs mo.
Daming issue ng SU7:grin:
Xiaomi E-Car
