Results 11 to 17 of 17
September 19th, 2010 11:41 AM #11
It appears from the video to be no more than a oil air separator like a oil catch can with will filter out the gunk from your crank case that goes back into your intake. You can make one on the cheap with a air water r from a air compressor they work great for keeping your intake clean and reducing smoke but there is no magic to them. And it will significantly cut own on black smoke. It's one of the first things you should do to any diesel. Look in your intake pipes or intercooler pipes and note all the oil residue. This helps eliminate almost all of that.
I don't know what electronics they could possibly be hooking up that would do anything to effect that. Looks like pure gimik to me.
[ame="http://www.youtube.com/watch?v=DapnOmvhF9U"]YouTube - DIY oil catch tank using Air Water separator[/ame]
September 19th, 2010 01:13 PM #12
This device is also a copy of another scam device with the same name.
http://www.sonecare.com/web/index.ph...d=19&Itemid=28
http://www.sonecare.com/web/images/r...d2000g_arb.pdf
Quote from the site.
Treatment Chamber - This is connected between the PCV (Positive Crackcase Ventilation) and the engine's intake manifold. The treatment chamber breaks down the hydrocarbons and other exhaust gasses from the engine before feeding it back to the intake manifold. It works like the Air Ionizers that we use in our homes, it purifies and breakdowns gasses and particles by the use of electricity. This results in return gasses that are easily burned when reintroduced back to the cylinder, which would mean cleaner emissions and better gas mileage.Power Supply Unit - This provides the necessary voltage and power that the Treatment Chamber requires to do its magic. It is made from only high grade parts to withstand heat, moisture and vibration in the engine compartment. It takes in 12Vdc and draws only a small amount of current, around 160mA.
Which is simply a 3/8" barbed check valve. Like the link below.
http://www.microchek.com/html/38b38b.html
If you see the words Testimonials it's a scam product period.
- Sep 2008
- 45
September 22nd, 2010 12:09 PM #13Do we have that device used in "DIY oil catch tank using Air Water separator" here in Manila? Hows much? It will help reduce the black smoke of my car (crosswind XT) based on your comment.
Thanks.
- Jan 2008
- 380
September 22nd, 2010 01:14 PM #14Do we have that device used in "DIY oil catch tank using Air Water separator" here in Manila? Hows much? It will help reduce the black smoke of my car (crosswind XT) based on your comment.
- Sep 2008
- 45
September 22nd, 2010 01:18 PM #15
- Sep 2006
- 1,335
- Sep 2008
- 45
December 23rd, 2010 02:48 PM #17
