Results 51 to 60 of 70
- Aug 2006
- 3
August 30th, 2006 12:34 AM #51Originally Posted by ;24778
- Aug 2006
- 3
August 30th, 2006 01:20 AM #53
simota? siguro mga 1.5k sa banawe.
im using HKS supa hybrid filter on my a32. after installing biglang tumaas yung rpm. normal lang daw yun since nag aadjust pa yung ECU. after a few minutes ok na.
August 30th, 2006 08:02 AM #54
Tanong lang po... saan ba gawa yung Simota?
Kasi, um, parang tamang-tama e sumisimot ng hangin...
- Sep 2003
- 43
September 30th, 2006 02:09 AM #55sir auto xer yung nilagay nyo na k&n sa expe, drop in po ba? no problems lumabas? sabi kasi nila mag check engine raw pag nilagyan ng ibang filter.
- Oct 2008
- 85
October 21st, 2008 06:51 AM #56
it may happen, esp on computerized engines (vvt-i, vtec) lalo na kung mali yung pagkakakabit nung air intake. the fuel air mixture will be so lean that it would cause knocking. (the feeling when you go below ideal idle rpm)
in general, air intakes (short and cold) will increase hp at higher rpms, especially on cold air intakes. it will increase fuel efficiency due to increased hp. i don't know its effect on the torque though.
- Oct 2008
- 85
October 21st, 2008 06:54 AM #57
May 22nd, 2009 08:53 PM #58
mga masters, i have read some feedbacks that simota filters are not good. there were test results showing that stock filters actually perform better than simota filters. ano masasabi nyo dito?
May 22nd, 2009 09:47 PM #59
May 22nd, 2009 10:36 PM #60
nabasa ko dito noon.
simota filters delivers more or less the same air by k&n but the filtering capabilities put it down.
Roadstar is reliable.
Finding the Best Tire for You
