Originally Posted by
kompressor
In fairness to the others, let's try to exercise constructive criticism instead of using a condescending tone. Condescension will only invite arguments instead of healthy discussions.
BTT:
*KIANTOT, I believe you didn't experience overheats during your first 90k kms, right? It's living proof that a properly functioning cooling system does not require the removal of the thermostat. It's still better to find the root cause once an engine overheats.
My assumption is that you may be using a good multigrade oil that adjusts to your engine's temperature that's why I also assume that your engine's compression is still in very good condition even after the mileage it incurred. However, did you notice a slight difference in your fuel economy after the thermostat is removed? Just like what was said earlier, a diesel engine is very dependent on the combustion chamber's compression and TEMPERATURE. Diesel injected at the same compression ratio but with a lower temperature will have a different burn compared to diesel injected at an engine's optimal operating temp vis a vis with its matching compression ratio. Just like with my experience, I consumed more diesel before I found out that the mechanic removed the thermostat. The difference is not that much during highway (however, still noticeable) driving but really mattered on city driving. Pag mas mababa kasi ang temperature, the more you need to step on the throttle to attain more power but at the cost of smoke and fuel economy.
