Results 1 to 10 of 23
December 18th, 2008 03:41 PM #1
Hi po mga tsikooters,
I'm planning to block the EGR of my bighorn (4JG2 Engine) any inputs (positive and negative) kung anu po magiging epekto nito after ko magawa.
TIA
December 18th, 2008 03:52 PM #2
more power.. pero may nagsasabing lesser daw usok...mayroon namang ngiging mausok.... pero most nagsasabi more power.
December 18th, 2008 04:12 PM #3
so far sa mga gumawa niyan dito more power...........kasi hindi uso dito yung truck na ma usok kahit medyo matanda na..........
December 18th, 2008 04:37 PM #4
the best benefit would be lesser carbon deposits and better oil lifespan. power gain and smoke reduction is barely noticable.
cons will be an increase of Nox. I have no idea if emmision test detects this...Last edited by rion; December 18th, 2008 at 04:40 PM.
December 18th, 2008 05:11 PM #5
December 19th, 2008 11:37 AM #7
Ah I see.. So there would no overheating problem after blocking the EGR?
The only cons is more nox will come out from the exhaust?
December 19th, 2008 11:50 AM #8
It depends on the car's tuning. Without EGR, the temps at low-load cruising might increase as the engine "leans out". Some engines can take this, as stock tuning is very rich (hence the smoke... too much fuel entering the combustion chambers), but if your car is properly tuned, it will run hotter.
And no, we don't test NOx. Local emissions centers test hydrocarbon emissions HCO and particulate emissions, both of which will be decreased by blocking off the EGR.
December 19th, 2008 11:52 AM #9
The car will still run with a disconnected EGR but it might have detrimental effects on your exhaust emmision and catalytic converter. However, most cars nowadays have their EGR valve directly connected to the engine idle control system through ecm, so you could possibly find disconnecting will alter idle speed or cause stalling.
The EGR stands for Exhaust Gas Recirculation. Its function is to reduce an exhaust emission that was not being cleaned by the other smog controls. Oxides of nitrogen (NOx) are formed when temperatures in the combustion chamber get too hot. At 2500 degrees Fahrenheit or hotter, the nitrogen and oxygen in the combustion chamber can chemically combine to form nitrous oxides, which, when combined with hydrocarbons (HCs) and the presence of sunlight, produces an ugly haze in our skies known commonly as smog. Wag kanang magkalat kawawa ang magiging anak mo pag nalanghap nila ito.
December 19th, 2008 03:09 PM #10
I see thanks.
ay, Oo nga. I forgot, hindi pala lahat sasakyan ay benefits. I had made a lot of research about this. nakalimutan ko lang.
in my personal experience, the clean steel plate we made as a blocking plate, in few weeks palang, it catched a lot of carbons. the engines didn't become cooler or hotter for that matter.
90's gen vehicles doesn't have EGR afaik. like fx,L300's,revo,hilux etc..Last edited by rion; December 19th, 2008 at 03:16 PM.
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
