Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Hi po mga tsikooters,
    I'm planning to block the EGR of my bighorn (4JG2 Engine) any inputs (positive and negative) kung anu po magiging epekto nito after ko magawa.
    TIA
  2. #2
    more power.. pero may nagsasabing lesser daw usok...mayroon namang ngiging mausok.... pero most nagsasabi more power.
    Jun 2008
    so far sa mga gumawa niyan dito more power...........kasi hindi uso dito yung truck na ma usok kahit medyo matanda na..........
    the best benefit would be lesser carbon deposits and better oil lifespan. power gain and smoke reduction is barely noticable.
    cons will be an increase of Nox. I have no idea if emmision test detects this...
    Quote Originally Posted by rion View Post
    Depends on the test apparatus. But local emissions testing do not test for NOx.
    ah I see. ano po ba yung basis sa local test natin?
    Ah I see.. So there would no overheating problem after blocking the EGR?
    The only cons is more nox will come out from the exhaust?
    Aug 2004
    It depends on the car's tuning. Without EGR, the temps at low-load cruising might increase as the engine "leans out". Some engines can take this, as stock tuning is very rich (hence the smoke... too much fuel entering the combustion chambers), but if your car is properly tuned, it will run hotter.
    And no, we don't test NOx. Local emissions centers test hydrocarbon emissions HCO and particulate emissions, both of which will be decreased by blocking off the EGR.
    May 2007
    The car will still run with a disconnected EGR but it might have detrimental effects on your exhaust emmision and catalytic converter. However, most cars nowadays have their EGR valve directly connected to the engine idle control system through ecm, so you could possibly find disconnecting will alter idle speed or cause stalling.
    The EGR stands for Exhaust Gas Recirculation. Its function is to reduce an exhaust emission that was not being cleaned by the other smog controls. Oxides of nitrogen (NOx) are formed when temperatures in the combustion chamber get too hot. At 2500 degrees Fahrenheit or hotter, the nitrogen and oxygen in the combustion chamber can chemically combine to form nitrous oxides, which, when combined with hydrocarbons (HCs) and the presence of sunlight, produces an ugly haze in our skies known commonly as smog. Wag kanang magkalat kawawa ang magiging anak mo pag nalanghap nila ito.
    I see thanks.
    ay, Oo nga. I forgot, hindi pala lahat sasakyan ay benefits. I had made a lot of research about this. nakalimutan ko lang.
    in my personal experience, the clean steel plate we made as a blocking plate, in few weeks palang, it catched a lot of carbons. the engines didn't become cooler or hotter for that matter.
    90's gen vehicles doesn't have EGR afaik. like fx,L300's,revo,hilux etc..
    Hi sir Niky,
    Can you elaborate what you have said earlier, I'm not familiar with term you used. "the temps at low-load cruising might increase as the engine "leans out". Some engines can take this, as stock tuning is very rich"
    Thanks
    If I remember it correctly, a comment from a mechanic's blog. EGR is suppose to cool down the engine on idle since EGR is only activated on idle and low rpm. some Exhaust is sent back to the engine's air intake thus making the fuel less combustable on idle making it cooler on idle and low rpm.
    EDIT: I just remembered, I don't think all vehicles that has EGR is deactivated on high RPM. because when we disabled the EGR by blocking it's vaccum pipe. then put a blanking plate between the exhuast and intake pipe hole. there are still carbon deposits sticking in the blanking plate's exhaust side when we opened it weeks later despite disabling the EGR control. I think it still mixes little exhaust back to the intake on high rpm. while on low rpm/idle a bit many more.
    Aug 2004
    If it's open at high load, then the EGR is sticking open and there's something wrong with the EGR valve.
    Regarding temperatures at low-load cruising... EGR is active mostly at low-load, low-throttle situations at low to medium rpms. At high rpms, EGR is closed so the engine can make the most power. At low rpms, having exhaust air, which is low in oxygen, mixed with the air-fuel mixture coming from the intake and injectors, allows the engine to burn less fuel than otherwise. In other words, the computer can set the engine to "lean-burn" (where it injects less fuel per volume of air than it normally does).
    A short explanation: Stoichiometric ratio is the ratio at which a volume of fuel burns precisely all the oxygen given to it. For gasoline this is 14 parts air to 1 part fuel. If there is too much fuel, this is running "rich"... Running rich has one advantage... the evaporation of the excess fuel draws heat away from the engine. If there is too little fuel, this is running "lean". This causes engine temperatures to go up. A side effect is that nitrous oxides are formed due to all that excess oxygen floating around. What the EGR valve does is dilute the incoming air with exhaust... which has almost no oxygen in it... so that the percentage of oxygen in the intake air is less... so even if you're running at a 16:1 or 17:1 ratio, due to the lesser percentage of oxygen, it's just like running at a 13:1 or 14:1 ratio.
    So what happens when you block off the EGR, the air-fuel ratio becomes leaner. This is not a big problem on most vehicles, which are tuned to run "rich". But some vehicles are already tuned to run "stoich" or close to it, so those engines will run hotter. But if your vehicle doesn't have an O2 sensor, I don't think it's a problem.
    Ah ok now I understand the principle of having an EGR so what I must do for now is to check the valve of EGR if it is funtioning well and not block the EGR is that right?
    Mar 2007
    when I discon my EGR, my check engine will light up. I put it back hehe
    Is EGR already on most modern engine like VVTi, D4D of toyota?
    I have no idea that there is such function on air and exhaust system.
    Thanks
    myroon na daw ang innova diesel. but revo and older hi-ace wala pa afaik.
    Sep 2006
    Quote Originally Posted by batosai View Post
    I would first check/block the vacuum line to the EGR valve, then check the valve and control system.
    Sep 2006
    Correct tayo jan. Good for the environment pa.
    Quote Originally Posted by suysuy View Post
    the solution to this is not to block the egr control but use a blanking plate. but I wouldn't do it to my new cars. or Maybe I'll use a blanking plate with small holes in it, so it will least catch some carbons and soots. and clean it up once a year.
Pro & Cons of EGR Blocking
