Results 1 to 6 of 6
- Feb 2008
- 577
May 29th, 2008 08:24 AM #1Hi,
I have rebuilt my carb and I am currently tweaking it for appropriate fuel consumption. Although the car runs smoothly, I still want to get actual data for my A/F mixture. Tanong ko lang po is saan merong ganitong services? Sa gasolinahan wala, sa casa wala. Sa emission testing centers naman hindi nila covered ang A/F mixture.
Thanks
BANNED BANNED BANNED
- Jul 2003
- 2,267
May 29th, 2008 07:30 PM #2ndi pa ako nakarinig ng ganyang service sa carb.
nway, search mo yung post ni wildthing about DIY carb adjustment ng a/f mixture.
- Jun 2006
- 91
May 30th, 2008 02:33 AM #3mahirap yata talaga sa carb the most you can do is learn to read the plugs...im guessing you already know that
- Feb 2008
- 577
May 30th, 2008 07:59 AM #4yup, i guess i'll have to settle for that move.
in any case, follow question narin, how would you know if you have the right quantity of a/f mixture in the cylinder (not the ratio, but the actual amount of mixture being burned)?
kung baga, how would i know if the cylinders are receiving the right amount of mixture volume?
- Jan 2008
- 380
May 30th, 2008 08:51 AM #5Pa-exhaust gas analyzer mo kaya, search the web na lang for more info. Dati ang sabi nila basta walang 'offensive kind of usok' at medyo nagtutubig yung exhaust ay ok yung timplada ng A/F mix. Saka dapat walang sabit ang takbo at tunog ng makina kahit low or high RPM ka.
- Jul 2003
- 2,267
May 30th, 2008 09:09 AM #6you dont have to worry about this. the cylinder will receive the same volume of air/fuel mixture on every intake stage of combustion process. the variable factor would be the density (and of course mass) of the mixture since density of air varies accdg to the temperature.
if the air passage is restricted, the engine will just stall. try removing the air cleaner and block the carb with ur hand.
ok din yan exhaust gas analyzer kung meron sa mga shops. baka sa emission testing center pwede. or amuying mo na lang yung usok ng kotse hehehe
Xiaomi E-Car
