Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Sep 2013
    mga sir ask ko lang po…nagffluctuate yung rpm ko pag naka-stop, tapos may vibration din, tapos napapansin ko minsan lumalala nginig to the point nararamdaman ko na cya sa seat ko sumasabay pa yung surge ng vibration sa fluctuation ano kaya yun? Honda city 2002 type z manual trans. 112k mileage na nabili ko lang 2 months ago
    Feb 2009
    Quote Originally Posted by aeolian_mood View Post
    is your malfunction indicator light on or flashing? is it misfiring? what is your engine speed at idle? does this happen when the engine is cold or warmed up?
    Sep 2009
    Servo/Throttle problem.
    try mo din muna pa tune-up and palinis MAF and throttle body.
    Jul 2010
    Check na rin yun engine support baka sira na.
    Oct 2013
    pareho kami ni sir TS, same ride din tayo, yung sakin naman nag-ffluctuate lang ang RPM ko pag sa stop and go traffic, pag derecho naman ang byahe ko smooth naman, ano kaya problema pag ganun? kaka-tuneup and change oil ko lang nito last week e
    Dec 2013
    Sir try mo palitan air cleaner maybe clog na yan,den spark plug,or faulty ignition coil, check mo din fuel pump mo baka nadumi na galing sa tank or yung fuel filter mismo
    Dec 2013
    Carbon deposits in the throttle body and idle air controller will be the primary cause. Fuel will not be able to clean
    this part of the engine so it has to be manually cleaned..
    Try getting an air intake cleaning service. Suzuki in Pasig and Chevy in UN Manila will do the service for your vehicle regardless of brand
    Feb 2014
    Ts, pa update nman dito sa naging prob ng oto mo? Same prob kc tau, naayos nyo po ba? Ano po naging sira?
    Posted via Tsikot Mobile App
    Apr 2008
    patanggal mo yung throttle body for cleaning, make sure lang na dun sa marunong gumawa mo dalhin lalo na kung may mga electronic components na. this is the first thing i would do for this issue. it happened to me more than once na and this solves the issue. hth!
    Feb 2014
    Quote Originally Posted by dongsky07 View Post
    Sir salamat po sa reply, kaso nalinis na po nung mekaniko ung throttle body last friday.. Oto ko po pla is honda city 97 matic. Mga iba pa po plang ginawa sa oto ko are, tune up, palit fuel filter kagabi lng, pero na fluctuate pa rin pero hindi na ganun kadalas kagaya nung dati. may iba pa po kayang panggagalingan ung sakit ng oto ko? Thanks in Advance po sa mga sasagot.
    Feb 2009
    i hate to cross the bridge before i get in front of it, but the most common fault of this symptom is a bad tps. your tps has three terminals. check continuity/resistance between the top and the bottom terminals. if the resistance is infinite, it's time to replace it. if there is continuity and less than infinite resistance, do a sweep between the middle and either top or bottom terminal of the sensor. if at somewhere about 40% throttle opening you find a glitch, the tps is bad. try running the engine at around a threshold of 2000 rpm, this is the most common engine speed when the engine "hunts" if the tps is faulty
    Jun 2011
    check also for vacuum leaks and clean IACV
    Feb 2014
    Sir jick.. Ano po ung tps?
    Sir buging... Ano nman po ung IACV?
    Another incident knina lng, pag start ko ng oto mejo mataas ang rpm.i remember mga 1200, wlang apak sa gas..tapos tumaas pa bigla i believe hanggang 1500-2000, tapos biglang bigla din bumagsak ang rpm tapos tuluyan syang namatay. Hindi ko inistart muna agad, then inistart ko 1click nagstart nman sya with normal rpm range. Kaso along the way may time na bumabagsak pa rin ang rpm pag naka idle pero awa ng diyos nakabalik pko ng bahay ng hindi namamatayan. Patulong nman po
    Jun 2011
    Kapag lumamig ang oto at inistart, for sure mataas ang idle and its normal sa oto natin at dapat kusang bababa yun in few minutes.
    Hmm, biglang namatay. Check/replace fuel pump, check fuel lines and Check/replace fuel filter. I recently have the issue, ok siya in 1-2km run after that walang anu ano, biglang mamatay ang oto. Undetected ang fuel pump maski pa-scan mo.
    IACV - Idle Air Control Valve or Servo - look ka sa net on how to DIY or pabaklas mo sa mechaniko para linisin yung Throttle Body, IACV, MAF (if equip)
    Yung sa akin, pinagawa ko eh replace fuel pump, clean the gasoline Tank, replace fuel filter, clean TB, IACV and MAF. Ayun nawala na yung problema ko na biglang babagsak ang RPM at mamatayan ka sa kalsada na di mo alam kung ano nangyari.
    Ang problema ko naman sa akin mataas ang rpm pagnaka idle... 1200 tapos minor nya nasa 1000
    Feb 2014
    Quote Originally Posted by Buging_King View Post
    madami pa plang hindi nagawa sa oto ko, cge po sir ipacheck ko po lahat ng yan, ang nagagawa po plang kc is clean throttle body and change fuel filter. salamat po pla sir.
    Feb 2014
    Update ko kau sir, yesterday ni-replace ko po ignition coil. So far steady na po ang idling ng oto on nuetral, at hindi na sya namamatay or hard start. Nung binuksan kasi ng mekaniko may konting nabago sa complexion ng cover ng ignition coil. Prang may konting sunog, pero since nung pinalitan nga e hindi na ulit nagloloko ang oto.
    Apr 2010
    Quote Originally Posted by ronskiee View Post
    Sir, brand new ba yung kinuha mong coil or surplus? Magkano po bili nyo? TIA
    Feb 2014
    Quote Originally Posted by PamelaAsistio View Post
    Brand new Japan replacement po, P1,800.00 po sa banawe.
RPM fluctuation when on complete stop
