Page 51 of 52 FirstFirst ... 41474849505152 LastLast
Results 1,001 to 1,020 of 1023
    Quote Originally Posted by bongbojador View Post
    Yes cvt, just change my transmission fluid sa casa during my 40k pms, 45k na sya ngayon, using fully synthetic oil din, balak ko sana sa labas na pa change oil
    sa labas na ang oil change. twice a year with some decent synthetics.
    cvt fluid change sa labas nadin.. drain and fill din naman. measure lng how much lumabas. palitan with the same amount with fresh cvtf
    brake fluids din [emoji6]
    #1002
    Yes sa labas na nga lang, mag 7 yrs na din naman yung lancer ko,, thanks again for the reply stock
    Nov 2003
    #1003
    yes 5w30 or 10w30 should be used for your car.
    Quote Originally Posted by speedyfix View Post
    sir meron kayo cvt fluids?
    ano brake pads available sa inyo?
    do you do brake caliper greasing?
    meron na suspension services? like bushing or shock replacements?
    Nov 2003
    #1005
    sir meron kayo cvt fluids? -- no stick with oem fluid.
    ano brake pads available sa inyo? -- normally bendix
    do you do brake caliper greasing? -- yes we can
    meron na suspension services? like bushing or shock replacements? -- yes we do
    please see above!
    #1006
    Sir speedyfix san ang shop nyo?
    #1007
    Their shop is located at 308 P. Guevarra corner Sea View, San Juan
    Nov 2003
    #1008
    thanks vinj!
    #1009
    Ok thanks
    #1010
    Sir speedy how about my ranger wildtrak 2015, 32k km, what type of RP oil is best
    hmm meron na kaya 30w hdeo ang speedyfix?
    May 2015
    #1012
    Any experience with Royal Purple 0W20? i've been using Royal Purple 5w30 for the past 3 years and i'm planning to try Royal Purple 0W20 next oil change hoping to improve FC. Car is CRV 2008 65k kms.
    Thanks
    #1013
    Quote Originally Posted by shiro View Post
    Thanks
    I'd stick to 5w30. First the fc improvement will be minimal, and secondly, 20 weight is not ideal for hot climates.
    #1014
    HondaPH uses their "green" 0w20 FS oil as their synthetic option for all their models nowadays. It has been some years already since they stopped using the old red-label 5w40 VTEC LEV FS oil. I have tried it on our previous gen City and Jazz.
    #1015
    Subaru used to recommend using 0w20 oil for naturally aspirated Foresters. Then a few years ago, they told us to switch to 5w30 iirc. Now I'm getting confused.
    Apr 2014
    #1016
    Diba masyado nang malabnaw ang 0w20 for our weather?
    Jan 2018
    #1017
    Dealership said So? Which one?
    Stay hungry. Stay humble.
    #1018
    Quote Originally Posted by stayhungry View Post
    There was a discussion about it on one of the Subaru threads. Haven't visited a Subaru dealership since 2013.
    #1019
    As per the manual of the Forester SJ, the non-turbo Foresters (FB20 engine) have a recommended 0w20 viscosity with 5w30 as an alternative. I may have to check again, to be sure.
    The dealership may have switched to a different supplier and the new supplier does not carry the 0w20 viscosity. As long as the viscosity is within the manufacturer's limits, that is just fine.
    Quote Originally Posted by chronicle View Post
    Nope. Honda would not be using their 0w20 for all their gas model lineup if the 20 weight oil is too thin for our climate. Ford's Ecoboost engines also have a recommended 5w20 viscosity but most local Ford dealerships do not offer such a viscosity. Ford casas use 5w30 oil instead.
    #1020
    You are correct.
    I think this IS the reason.
Royal Purple Oil
