Originally Posted by
robin_micmac
If you're engine is a 4G32, I think the GTX 20W50 is just fine as the engine is of an older design. it has wider tolerances than modern engines. but using a 10w40 would be ok as well as it is lighter on your engine and its still a 40. if you have budget try using Castrol Magnatec 10W40 API SM. That's what i use in my rover mini.
