Results 1 to 20 of 20
    Jan 2004
    Hi guys, has anyone tried using Fuel Injector cleaners? I have a diesel ride kasi and its been a long time since na palinis ito. Try ko lang yung cheaper alternative kung may positive and effect (brands like STP) ty
    Dec 2007
    bro, i've used one of those injector cleaners di ko lang matandaan brand pero lalo lang nag worsen yung problema. if smoke ang problem mo sa diesel ride mo, have your nozzle tips (injectors) checked kasi baka di na maganda ang distribution ng diesel fuel. next thing to do if wala mangyari is calibration ng injection pump which is a little bit costly pero yan talaga ang solution for smoke problems sa diesel. i also have a diesel ride and after nozzle tip replacement and injection pump calibration, wala na usok, tipid pa sa diesel, lumakas pa hatak.
    Quote Originally Posted by rdv282 View Post
    Sir, matanong ko lang ano sasakyan ninyo? sino gumawa?
    I'm a regular user ng STP injector cleaner. 9 years na yung kotse ko pero di ko pa napalinis ang injector kahit minsan. Di ko alam kung effective nga sya, pero pakiramdam ko ay gumaganda ang takbo kahit papano pag naglalagay ako ng ganon, pero di lang din sure kung dahil dun sa jet fuel additive ng STP injector cleaner.
    Gas engine nga pala car ko.
    Sep 2004
    I also use STP. For me, ok naman ang naging experience ko, on both my Accord and former Sentra.
    I also used Outlaw (twice more expensive than STP), and I felt it helped in stabilizing idling issues I had with my Sentra (which was later traced to a dirty IACV/TB).
    Sep 2004
    Use injector cleaner (fuel additive) when you are about to do an oil drain (change).
    It tends to change the engine oil chemistry that might have some effect on the engine when used for a relatively long time.
    I have used the Cyclo cleaner.
    Quote Originally Posted by vicvic View Post
    i also used also cyclo injector cleaner on the 13 old car. I used it 2,000km before oil change. There is a little difference in engine performance also in fuel consumption, i guess i should used it with our maintenance services (e.g change oil, tune-up)
    Sep 2006
    Ive heard that the 3M carb cleaner can also be a substitute-just spray half of the can contents in the gas tank (at full tank). But havent tried it yet because I don't know if this is a good practice.
    Jul 2003
    just curious how a fuel additive or injector cleaner would affect engine oil when fuel and engine oil do not directly come in contact with each other?
    is it due to the blow by gases which comes from the crankcase then recirculated back to the intake manifold?
    Nov 2003
    on a diesel, injector cleaners are not an alternative to getting periodic calibrations.
    Jul 2006
    Actually the added biodiesel content in the current diesel fuel offered there in the Philippines adds to the cleaning effect and so you won't need a separate injector cleaner anymore.
    Personally I use only two products: Liqui or Lubro Moly Diesel Purge and Diesel Kleen, but those are offered here in the US. If you have access to them, they're worth their weight in gold.
    Sep 2006
    Diesel fuel injection cleaners may work if the injectors are basically in good condition, and only need cleaning.
    Diesel fuel injectors have a service life.
    Even the best cleaning product will not work on faulty / bad injectors.
    Remember, mileage is wear.
    Bye,
    Dieseldude
    Jan 2004
    hi guys, i just bought the STP branch for around P125. Im gonna use it later (with full tank of gas). Bigay ko feedback after a few days. TY
    Aug 2007
    ok lang ba gamitin to kahit hindi full tank ang gas mo (ex. half)? ano ba magandang brand?
    Feb 2017
    For current users of this additives, are you still continuing to use them, stop or just have them calibrated?
    PAJ 4M40 MORE POWER!
    Jul 2013
    Quote Originally Posted by 94mitsukid View Post
    if you have an old humidifier na nakatambak, ipa convert mo ng ultrasonic cleaner sa mga electronic shops. humidifiers are not good to use sa atin. lumalala asma.
    Mar 2015
    I recomend Chevron techron complete fuel system cleaner para sa mga gas engines,lagay lang sa almost empty tank bago magpakarga(half tank pra concentrated).
    At sa diesel naman,liqui moly diesel purge(buhos directly sa diesel filter housing kada palit ng filter) or lubro moly diesel additive sa half tank of diesel din hinahalo.da best mga yan tested na
    Sent from my E6853 using Tsikot Forums mobile app
    Jul 2013
    I just replaced the injector nozzles today. are injector cleaners advisable as a preventive maintenance? Btw i also replaced the old fuel filters.
    I use stp 5in1 fuel system cleaner after fuel filter replacements..
    Oct 2015
    mga sir ano po recommended cleaner for CRDi?
Need feedbacks on using Fuel Injector Cleaners
