Results 1 to 10 of 20
- Jan 2004
- 46
December 27th, 2007 09:21 PM #1Hi guys, has anyone tried using Fuel Injector cleaners? I have a diesel ride kasi and its been a long time since na palinis ito. Try ko lang yung cheaper alternative kung may positive and effect (brands like STP) ty
- Dec 2007
- 17
December 27th, 2007 10:33 PM #2bro, i've used one of those injector cleaners di ko lang matandaan brand pero lalo lang nag worsen yung problema. if smoke ang problem mo sa diesel ride mo, have your nozzle tips (injectors) checked kasi baka di na maganda ang distribution ng diesel fuel. next thing to do if wala mangyari is calibration ng injection pump which is a little bit costly pero yan talaga ang solution for smoke problems sa diesel. i also have a diesel ride and after nozzle tip replacement and injection pump calibration, wala na usok, tipid pa sa diesel, lumakas pa hatak.
- Jan 2007
- 409
December 27th, 2007 11:35 PM #3
December 28th, 2007 09:11 AM #4
I'm a regular user ng STP injector cleaner. 9 years na yung kotse ko pero di ko pa napalinis ang injector kahit minsan. Di ko alam kung effective nga sya, pero pakiramdam ko ay gumaganda ang takbo kahit papano pag naglalagay ako ng ganon, pero di lang din sure kung dahil dun sa jet fuel additive ng STP injector cleaner.
Gas engine nga pala car ko.
December 28th, 2007 09:48 AM #5
I also use STP. For me, ok naman ang naging experience ko, on both my Accord and former Sentra.
I also used Outlaw (twice more expensive than STP), and I felt it helped in stabilizing idling issues I had with my Sentra (which was later traced to a dirty IACV/TB).
- Sep 2004
- 59
December 28th, 2007 10:55 AM #6Use injector cleaner (fuel additive) when you are about to do an oil drain (change).
It tends to change the engine oil chemistry that might have some effect on the engine when used for a relatively long time.
I have used the Cyclo cleaner.
December 28th, 2007 11:30 AM #7
December 28th, 2007 11:58 AM #8
Ive heard that the 3M carb cleaner can also be a substitute-just spray half of the can contents in the gas tank (at full tank). But havent tried it yet because I don't know if this is a good practice.
BANNED BANNED BANNED
- Jul 2003
- 2,267
December 28th, 2007 02:24 PM #9
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 1st, 2008 12:34 PM #10on a diesel, injector cleaners are not an alternative to getting periodic calibrations.
Monk-owned R53
