Hi guys, has anyone tried using Fuel Injector cleaners? I have a diesel ride kasi and its been a long time since na palinis ito. Try ko lang yung cheaper alternative kung may positive and effect (brands like STP) ty
bro, i've used one of those injector cleaners di ko lang matandaan brand pero lalo lang nag worsen yung problema. if smoke ang problem mo sa diesel ride mo, have your nozzle tips (injectors) checked kasi baka di na maganda ang distribution ng diesel fuel. next thing to do if wala mangyari is calibration ng injection pump which is a little bit costly pero yan talaga ang solution for smoke problems sa diesel. i also have a diesel ride and after nozzle tip replacement and injection pump calibration, wala na usok, tipid pa sa diesel, lumakas pa hatak.![]()
I'm a regular user ng STP injector cleaner. 9 years na yung kotse ko pero di ko pa napalinis ang injector kahit minsan. Di ko alam kung effective nga sya, pero pakiramdam ko ay gumaganda ang takbo kahit papano pag naglalagay ako ng ganon, pero di lang din sure kung dahil dun sa jet fuel additive ng STP injector cleaner.
Gas engine nga pala car ko.
I also use STP. For me, ok naman ang naging experience ko, on both my Accord and former Sentra.
I also used Outlaw (twice more expensive than STP), and I felt it helped in stabilizing idling issues I had with my Sentra (which was later traced to a dirty IACV/TB).
Use injector cleaner (fuel additive) when you are about to do an oil drain (change).
It tends to change the engine oil chemistry that might have some effect on the engine when used for a relatively long time.
I have used the Cyclo cleaner.
Ive heard that the 3M carb cleaner can also be a substitute-just spray half of the can contents in the gas tank (at full tank). But havent tried it yet because I don't know if this is a good practice.
on a diesel, injector cleaners are not an alternative to getting periodic calibrations.
Actually the added biodiesel content in the current diesel fuel offered there in the Philippines adds to the cleaning effect and so you won't need a separate injector cleaner anymore.
Personally I use only two products: Liqui or Lubro Moly Diesel Purge and Diesel Kleen, but those are offered here in the US. If you have access to them, they're worth their weight in gold.
Diesel fuel injection cleaners may work if the injectors are basically in good condition, and only need cleaning.
Diesel fuel injectors have a service life.
Even the best cleaning product will not work on faulty / bad injectors.
Remember, mileage is wear.
Bye,
Dieseldude
hi guys, i just bought the STP branch for around P125. Im gonna use it later (with full tank of gas). Bigay ko feedback after a few days. TY
ok lang ba gamitin to kahit hindi full tank ang gas mo (ex. half)? ano ba magandang brand?
For current users of this additives, are you still continuing to use them, stop or just have them calibrated?
PAJ 4M40 MORE POWER!
I recomend Chevron techron complete fuel system cleaner para sa mga gas engines,lagay lang sa almost empty tank bago magpakarga(half tank pra concentrated).
At sa diesel naman,liqui moly diesel purge(buhos directly sa diesel filter housing kada palit ng filter) or lubro moly diesel additive sa half tank of diesel din hinahalo.da best mga yan tested na
Sent from my E6853 using Tsikot Forums mobile app
I just replaced the injector nozzles today. are injector cleaners advisable as a preventive maintenance? Btw i also replaced the old fuel filters.
I use stp 5in1 fuel system cleaner after fuel filter replacements..
