Results 1 to 10 of 14
- Sep 2011
- 20
September 2nd, 2017 03:57 AM #1I am planning to replace my car's spark plugs my self for the first time so I watched a couple of youtube videos.
Unfortunately, these video tutorials made me more confused.
They are talking about a spark plug gap thingy and correct torque or tightness. I can't even find a store to buy that gap gauge.
Are they really important or can I just buy a plug that is designed for my vehicle and just plug it in?
Any advice? Thanks!
September 2nd, 2017 04:22 AM #2
feeler gauge is necessary if you want to check the gap. if you do get the correct plugs.. its unnecessary. which car/year? which plugs did you get?
- Sep 2011
- 20
September 2nd, 2017 08:15 AM #3Hyundai accent 2012. Don't have the plugs yet. Can I ask the store to correct the gap for me?
- May 2011
- 481
September 2nd, 2017 08:25 AM #4Some spark plugs have protective sleeves to prevent accidental regapping when the plugs fall during handling from the manufacturer all the way up to the parts counter and beyond. Sometimes you need to regap for specific applications. To check the gap.use a wire feeler gauge. Use the correct :
Reach
Heat range
Seat type
And resistor type
September 2nd, 2017 08:28 AM #5
Plugs are pre gapped. Usually if you buy the OEM plug there is no need to adjust the gap. You just need to install them. What is the suggested gap per owner's manual? What is the OEM plug?
Sent from my SM-G7102 using Tsikot Forums mobile app
- Sep 2011
- 20
September 4th, 2017 08:00 PM #6I bought a pre gapped plug. New problem, the old plugs are too tight they are hard to remove.
Any suggestion how I can replace those pesky plugs? I
September 4th, 2017 08:11 PM #7
Which way are you turning?
Loosen = counter clockwise
Tighten = clockwise
Pre-gapped or not, it is usually good practice to check and "re-gap" the new plugs yourself.
- Sep 2011
- 20
September 4th, 2017 09:55 PM #8I bought a oem one specific to my car model to be sure.
I turned it counter clockwise. I already managed to pull one plug but the other plugs giving me a hard time.
- Jan 2008
- 4,726
September 4th, 2017 10:33 PM #9
September 5th, 2017 02:14 PM #10
While WD40 is okay on freeing seized or rusted up threads, too much of it will contaminate your sparkplug threads. Thus leading you to over tightening the new plugs (because madulas eh from all that WD40 leftover).
Try to use it sparingly, (the little red pipe is there for that).
You can use a short extension (iron pipe, etc. what's available) to give you more leverage.
Or, take it to a mechanic, and observe what he does. Para second time around, you know what to do.
Goodluck.
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
