Results 3,521 to 3,530 of 3899
- Sep 2013
- 630
October 14th, 2013 08:12 PM #3521Napansin ko pag oil filter lagi pinaguusapan baldwin, donaldson and fleetguard.
Pag i-rate sino top 1,2,3?
Saan din distributor ng donaldson and fleetguard?
October 14th, 2013 08:30 PM #3522
October 15th, 2013 11:31 AM #3523
Lower priced ang Baldwin compared sa Donaldson/Fleetguard and readily available ang filters need ko.
Baldwin - available sa Volmax - Binondo, Gigatrade - Grace Park, Caloocan City at Durasales - C3
Donaldson at Fleetguard - available sa W & L - 8th St, New Manila at Durasales - C3
October 15th, 2013 09:03 PM #3524
W&L did not have all of the Fleetguards I was looking for but the other shop had it. W&L is also selling the "fake" LF3564.
- Sep 2013
- 630
- Apr 2005
- 16
October 18th, 2013 07:47 PM #3526Sir, based on this discussion, mas "safe" ang mas mataas na BPV pressure kesa lower kasi di naman magbabara yung element basta basta so di needed magengage yung BPV. Tama? Kasi kung too low (say from 20 psi recommened, gagamit ako ng 8 psi), mag e-engage prematurely yung BPV pag rev ng engine? Did I get it right? Better if higher psi because the parameters needed to engage the BPV almost doesn't exist here compared to a "too low" psi that will prematurely engage just by simply accelerating?
- Mar 2012
- 27
October 19th, 2013 04:51 PM #3527
- Mar 2012
- 27
October 19th, 2013 04:59 PM #3528
- Sep 2013
- 630
October 20th, 2013 02:52 PM #3529^
xie xie
Pag malayo sa mga place na yan dapat by the dozen ang bili. Ang traffic papunta sa volmax at maghanap ka parking pa na obviously magbabayad ka pa 30 - 50pesos rate para sa 15minutes na transaction.
- Sep 2012
- 32
October 21st, 2013 02:10 AM #3530
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
