Did some research on which is better. 14PSID vs 20PSID. this filters have a bypass valve. So that when the filter is already clogged, magoopen up eto so that oil would still be supplied to the engine (unfiltered though). In a 14PSID limit filter. That valve opens once the pressure is higher than 14PSID. Same applies for 20PSID. So meaning it would take a longer time for the 20PSID to open when clogging occurs (takes more debris before it clogs compared to a 14PSID.
If you're on high rpm sabi nga ni sir EssB, that valve wont open up easily even though the oil pump works harder.
The question now would be the 6PSID difference be a big factor? or is it negligible?
