Results 3,111 to 3,120 of 3899
January 16th, 2013 03:49 PM #3111
January 17th, 2013 01:34 AM #3112
ganun? so it is going to harm my engine? hehe naku.. have been using mono grade for sometime na.. and may 3pails pa yata ako.. hehe ubusin ko paba? hehe
January 17th, 2013 09:27 AM #3113
Actually baligtad. Pag monograde malapot pa rin ang oil on cold starts kaya mahirap i-circulate.
Pag multigrade, malabnaw ang oil during cold starts then balik sa tamang viscosity pag operating temp na.
ex: 20w40, SAE 20 pag cold, SAE40 pag operating temp na.
Kelangan kasi malabnaw ang oil pag cold coz may tendency na bumaba halos lahat sa sump lalo na pag walang one-way valve ang gamit na oil filter, so kelangan mas madali i-recirculate pag nag start ang engine.
Gumamit din ako ng monograde dati. Ang rule of the thumb ko on monograde is to make sure na walang engine load (idle lang) ang engine for a minute after I start the engine cold.
January 17th, 2013 04:38 PM #3114
so its ok po na ubusin ko monograde oil? warmup lang po muna on cold start? hehe
thanks:D
January 17th, 2013 05:05 PM #3115
January 17th, 2013 10:47 PM #3116
How many ten thousands kilometers can the BF7534 last before replacement ?
- Jun 2005
- 59
January 18th, 2013 12:58 AM #3117I want some clarification lang,since walang winter sa pinas or even lower than 15 degrees ang temperature so its safe to use sae40.The 15w is good for -20 degrees cranking.Why are we still need 15w-40 specially its expensive compare to monograde?
January 18th, 2013 02:59 AM #3118
Like Doc recommends TOP1 SDO and Delo 400 are the best bang for the buck...Not simply because they are multi grades but due to they're TBN rating. Maybe if you can find a locally available monograde oil with good TBN rating too you could use that and maybe share it with us...
- Jul 2011
- 262
January 18th, 2013 08:47 PM #3120
Gurus, I have a question regarding Baldwin B178 and B199. Same naman sila ng diameter and length but according also to the Baldwin website "Baldwin Filters E-Catalog"
B178 Anti-Drainback Valve
30 PSID By-Pass Valve
B199 Anti-Drainback Valve
8 PSID By-Pass Valve
The one I'm using now on our Vios 1.3 (BT223) is 8 PSID By-Pass Valve
What does the 8 or 30 PSID mean? May masamang effect ba sa engine if I used a lower number (8) than a higher one (30) and vice versa? Planning to use either B178 or B199 on the next oil change of my dad's Civic EK (PH15A engine). I checked the location of the oil filter (real quite hard to see, but I think it has a lot of space to cater to a longer oil filter). Thanks.
Here's the photo
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
