Page 306 of 390 FirstFirst ... 206256296302303304305306307308309310316356 ... LastLast
Results 3,051 to 3,060 of 3899
    Dec 2007
    #3051
    Then get Delo 400 it's TBN is 16 and with a gas engine you can easily take that to 15000klm with a Baldwin filter.
    #3052
    Diba hindi na recommended ang delo 400 sa gas na may catcon?
    Jan 2013
    #3053
    Doc I'm not sure that Delo 400 TBN is 16. I looked it up on the website you gave me for the caltex website and the TBN there is just 12.2
    http://www.caltex.com.au/productsand...n.aspx?ID=1639
    The price of Delo Gold Ultra is less than 200 pesos while Delo 400 is around 400 pesos (and really hard to find an auto supply or caltex station that sells it). Is it more economical to go with Delo gold than Delo 400 if the TBN difference is just 2 points?
    Dec 2007
    #3054
    Quote Originally Posted by Ammiel Barlis View Post
    You are correct. was thinking of a different one. Very high ZDDP content in Delo 400, You can look for Top 1 as well http://www.top1oil.com/products/diesel
    Jan 2013
    #3055
    doc after some more research i found out that the delo ultra gold they sell here in the philippines is different from the the delo gold ultra in the australian website. delo gold ultra 15w40 here in phils. is CH rated with 9.5 TBN based on the data sheet i downloaded while Delo gold ultra 15w40 from caltex australia website is CI rated with 10.2 TBN.
    Dec 2009
    #3056
    delo gold "ultra" here in the Philippines is CI-4 and global DHD rated... 200 plus to per liter
    "delo gold" is the one rated CH-4.... less than 200 per liter
    check the nearest caltex stations, they have delo gold ultra which is CI-4...
    Jan 2013
    #3057
    ok, i'll check for new stocks. what i got from my auto supply earlier this afternoon was just CH-4. I will have to find CI-4 Delo gold ultra from somewhere else. Thanks again
    Jan 2013
    #3058
    After checking the container it was indeed delo gold and not delo gold ultra. I asked for delo gold ultra specifically but failed to notice it was just delo gold that the sales lady gave me since i was on my way to work and a little bit in a hurry. My bad... To Doc, what is the best bang for the buck oil that I can get besides Delo Gold Ultra and Top1 SDO?
    Jan 2013
    #3059
    Doc Mobil Delvac MX has a high TBN of 12 and only around 210 pesos per liter in one of the distributors here in Pampanga. According to its MSDS it has 2500 ppm ZInc
    https://www.alexisoil.com/sites/defa...5w-40-msds.pdf
    Since my gas engine car does not have a cat con its not going to be a problem if i use it, but is this oil good fo 10,000 OCI on a 2012 montero sport of course with a bd28 filter partnered with it (my fathers car).
    Also why is the more expensive (by 2-3x) Mobil 1 Turbo Diesel Truck 5W-40 fully synthetic oil have a lower TBN of 10.7?
    #3060
    Here is the pds of the Mobil delvac MX being sold in the philippines. Mobil Delvac MX 15W-40
    For its zinc level, the pne you posted shows less than 2.5% but in some used oil analysis (UOA) i got from the net, zinc level is around 1,700ppm so hindi puwede sa gas engines with catcon. On the other hnd, Delo Gold Ultra, Top 1 SDoand Mobil 1 TDT 5w40 is about 1200ppm ang zinc.
Remote bypass oil filtration
