Page 165 of 390 FirstFirst ... 65115155161162163164165166167168169175215265 ... LastLast
Results 1,641 to 1,650 of 3899
    #1641
    Luberfiner is on par with Wix filters. I use their heavy duty Imperial XL series as one of my oil filters. It's a good filter.
    Is their luberfiner LFP3307 good for 10T kms oil changes too?
    Looks like this will be the fuel filter I'll be using... hehehe ..just cant find the fuel filter part number for my 4m40...
    Nov 2011
    #1642
    purchased luberfiner PH920 for my 3C engine (plastic only at the bottom and with box) and LF3528 for crosswinds (wrap with plastic from top to bottom and will free oil seals) from W&L yesterday.
    thanks doc for the correct numbers.^_^ and just waiting for when this bad boys will be into our vehicles.
    will post pictures of the new filters and the one that will be replaced next time.
    btw: they have fuel and water seperator/filteras well..was just not sure if that is compatible with the filters I have.
    Dec 2007
    #1643
    Yes it is, Luberfiners are for fleet service they are not over the counter filters.
    They are also made by Champion labs who makes ,Bosch, Mobil 1, and K&N oil filters.
    Here's your fuel filter. FP941F
    This filter is close to the a Donaldson and Fleetguard absolute * 35 microns nominal rating 15, The Baldwin is absolute *15 microns and 5 microns nominal. Baldwin makes a damm fine fuel filter. (absolute is 98.7%) (nominal is 50%) on the first pass.
    Dec 2009
    #1644
    *miko, bro, talaga bang may individual box yan?
    yes Bro, they are on individual box....
    #1645
    wow BG, jackpot sa W&L ah, hehe. Maganda pala din yang Luberfiner. Magkakano daw yang luberfiner LFP3307?
    Dec 2009
    #1646
    DOc,
    B161-S Oil Filter
    Microlite Full-Flow Lube Spin-on
    Fits:Ford, Honda, Mazda
    Doc, whats the meaning of microlite?? when it comes to filters?
    i'll be hording filters again this week... LOL.haha
    Dec 2009
    #1647
    Doc, my current filter is LF3644 with a 14 PSI relief setting
    i wanted to try
    B161-S(microlite according to site) has a 20 PSI relief setting (20mm longer than LF3644)
    B199 has a 8 PSI relief setting ( 40mm longer than LF3644)
    Whats your opinion Doc, ?? do i choose the lower PSI or higher PSI
    #1648
    dvldoc, just want to ask if the ff filter are interchangeable?
    B1422 vs. B7033 even though gasket is different?
    JS Filters :: Application Cross Reference and Image for JS : Oil (Spin-on) : C807J
    JS Filters :: Application Cross Reference and Image for JS : Oil (Spin-on) : C513J
    Also B173-S vs. B201-S, gasket is also different.
    baldwin b173-s, full-flow lube spin-on
    baldwin b201-s, by-pass lube spin-on
    #1649
    sorry double post
    Dec 2007
    #1650
    Microlite is Baldwins standard media. It is a mix between cellulose and microglass giving it a high efficiency and high flow. One of the reasons their filters are so good even in standard form and not the high efficiency ones.
    The B161-S is a bit longer than the B1402 which is the standard replacement so it will give you more filter surface and longer life, I always get the biggest filter that will fit on all my vehicles.
    4 baldwins should last most people at least a year unless your doing a extreme amount of driving. No reason to run them under 1200klm. Since they have more dirt holding capacity over most cellulose filters and a higher efficiency rating.
Remote bypass oil filtration
